Question about Logitech G25 Wheel And Pedals Set
When my steering wheel is straight, my car steers left.
    Sergeant:
    Champion:
  • 233 Answers
Try turning it all off and on again.
It that doens;t work try taking it to pro.
Good Luck...!
Hope I helped
Posted on Aug 02, 2009
I just had the power steering gear box changed in my 1994 Mighty Max. The steering wheel is now cocked to the left. What would be the cause and what would be the fix?
You missed a spline when installing the pitman arm on the steering box. Park the truck straight and remove the arm. with the arm off, unlock steering column and point the steering wheel straight. Lock the steering column. Then reinstall the pitman arm on the steering box carefully matching the splines in the arm to the shaft on the steering box. that should be close to running straight while driving straight.
Feb 28, 2017 | Cars & Trucks
WHY DOES THE HORN ON MY 1995 TOYOTA CAMARY ONLY WORK WHEN THE STEERING WHEEL IS FULLY TURNED TO THE LEFT OR RIGHT AND NOT WHEN THE STEERING WHEEL IS STRAIGHT AHEAD
pull the steering wheel and check the wear ring under the wheel that the brass contact plunger runs on
it is possible that for the straight ahead position the ring is worn away
Jul 11, 2016 | 1995 Toyota Camry
When steering is centered the left wheel is out to the left and the right is straight
Unless you have had an accident or Kerbed the wheel it is probably your tracking is out/ track rod end loose!
Sep 10, 2015 | Cars & Trucks
My steering wheel on Merc C280 1995 model. While driving I can move the steering wheel slightly left to right, but the car remains straight. Then the car will veere right and then left slightly without me...
Check steering wheel nut is tight, sometimes it may run loose. If it is tighten to specs and is still happening, splines may be worn on steering wheel.
Mar 04, 2015 | Cars & Trucks
2004 Toyota highlander steering wheel is locked but turned halfway, key wont turn and wheels are straight
there is a load on the lock pin in the steering column try turning the steering wheel a bit left or right to release the pin as you try turning the key.
Steering wheel locks never lock straight ahead as the idea is that if the car is being stolen it will turn a circle rather that move straight
Feb 21, 2015 | 2004 Toyota Highlander
When I make a left turn my steering wheel changes is neutral position
Something is loose on your steering linkage or suspension have a pro look at it, use a shop with an alignment rack available.
Aug 22, 2012 | 1994 Toyota Camry
Early cancelling of trafficator
What seems to be the problem with your turning signal cancellation, is the steering wheel is not in line with your wheels.
Meaning, when driving straight, take note on on where the steering wheel is positioned. If the spokes or logo on the steering wheel are turned or not level, then that's the reason for your turn signal is doing what it does.
The best way to cure this problem is take your vehicle to a wheel alignment shop that you trust, and tell the technition to position the steering wheel straight with the wheels.
Nov 30, 2011 | Ford Cars & Trucks
Recode steering angle sensor
For recode the steering angle sensor you must connect a diagnosis scantool to the data link connector of the car in order to access the ESP ECU (Electronic Control Unit), in other words programm again the steering angle sensor in the ESP ECU. Select the steering angle sensor programming (learning) menu, and follow the steps: put steering wheel in straight direction, then turn steering wheel to the left direction less 15 degrees, then to the right direction less 15 degrees, put steering wheel in straight direction again until the programming was done. Then the ESP light will turns OFF.
Aug 20, 2010 | Audi A6 Cars & Trucks
Logitech G25 Wheel And Pedals Set Logo
227 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
