Question about Dell OptiPlex GX620 PC Desktop
Optiplex gx620 USFF. no power to the machine
I have 2 optiplex gx620 USFF's. one works fine the other started to work ok, i was installing windows and then the power just dropped from it. I tried to reboot and there was no power running to the machine, I switched the power packs over and nothing. when i first plug it in, the power come on for a few seconds (mobo light solid amber) and then the power cuts out. At first I did get a low voltage warning and hit F1 to proceed and then half way through install the power dropped. Can anyone assist me with this? and yes I have tested both power packs and cmos batteries with the working machine and they are all ok. Its driving me batty and I cant figure it out! any information would be appreciated
  • Dell Master
  • 3,051 Answers
HELLO THERE:
THE FIRST THING YOU WILL NEED TO DO IS TO DOUBLE CHECK ALL THE CABLES AND POWER CORDS ARE FIRMLY INSTALLED NORMALLY REMOVE AND REINSTALL THE CORDS AND CABLES TO MAKE SURE THEY DID NOT COME LOOSE IF IT WONT BOOT THAN TRY TO REMOVE THE CD ROM AND THE HARDDRIVE CORDS AND CABLES FROM THE DEVICES AND TRY TO BOOT IF THE MACHINE IS NOW STARTING INSTALL THE CABLE AND CORDS 1 AT A TIME FOR EACH DEVICE AND BOOT UP THE MACHINE EACH TIME THIS WILL HELP YOU FIND OUT WHERE YOUR PROBLEM IS OK.
BEST REGARDS MIKE
Posted on Aug 02, 2009
Firewire port usff 7010
If you're asking if a Dell OptiPlex 7010 USFF will support Firewire the answer is No...Unless you purchase and install a Firewire card
The OptiPlex 7010 USFF has the following external connections:
  • Front Panel: one microphone connector and one headphone connector
  • Back Panel: one line-out connector and one line-in/microphone connector
  • Network Adapter: one RJ45 connector
  • Serial: one 9-pin connector; 16550 C compatible
  • USB 3.0: Back Panel - 2
  • Video: 15-pin VGA connector
  • 20-pin DisplayPort connectors - 2
I don't recommend any USB to Firewire convertors but if you can find a Firewire Convertor PCI Express Card you can try installing it but remember the USFF has only one Mini PCI Express 52-pin connector, I've highlighted a possible product. It allows for Firewire 800 speeds. The included optional internal Molex power connection is only required if your Firewire device doesn't have its own power adapter
May 07, 2014 | Dell Optiplex 7010 500gb Usff Ultra Small...
Firewire usff 7010
May 07, 2014 | Dell KIT OPTI 7010 USFF I5-3470 3.2G 2GB...
How to install window 7 64 bit my optilex gx620
Here's a video Dan Shibata suggested as a solution to your problem from YouTube:
Dell Optiplex 330 Running Windows 7 64-bit
May 08, 2013 | Dell OptiPlex GX620 PC Desktop
Dell optiplex GX620 doesnt start
1-3-1 through 2-4-4
Memory not being properly identified or used
http://support.dell.com/support/edocs/systems/opgx620/en/ug/tools00.htm#wp1120374
Feb 12, 2013 | Dell OptiPlex GX620 PC Desktop
Dell OptiPlex GX620 show orange light and refuse to boot up
  • Turn the machine off and unplug from power.
  • Locate and remove the CMOS battery.
  • Disconnect the hard disk from power
  • Leave it like that for a few minutes and the connect everything.
  • Start the machine now.
Worked for me,hope it does for you.Thank you!
Sep 28, 2011 | Dell OptiPlex GX620 PC Desktop
My computer is dell optiplex Gx620 and i install windows 7 operating system but sound driver is not working
You will need to visit the Dell website and download the Windows 7 drivers for your computer. Click their downloads/support button.
Take care!
damnor01
Aug 15, 2011 | Dell OptiPlex GX620 PC Desktop
On my dell optiplex gx620 all of the usbs front and back dont work after the windows loading screen but power is working, usb light works. i dont no what to do i have enabled them in bios and default...
my dell optiplex gx620 is coming on but its not passing the bios revision or the boot up page i have tried every thing removing the small battery in the mother board unplugging the hard drive, i even busted the whole system and it still not coming on. i have triied sending it into safe mode and the 1234 light are comming on i have runed out of option and i dont know what to do.this all started 3 days when i turned off the computer tried to put it on but after it came on pass the boot up page the screen was blank
Oct 01, 2010 | Dell OptiPlex GX620 PC Desktop
The light at the power nod has turned yellow and
buy a new computer, sorry but dell sucks
they are made to work for a certain amount of time not forever i worked at dell and yeah ............. i leave it that
May 08, 2010 | Dell OptiPlex GX620 PC Desktop
Lost resolution windows vista upgrade on GX260
Hi all,
I tried numerous solutions for this issue and none of them worked except this one. I tested it with Vista Ultimate and don’t know if other Vista versions have the same drivers but here’s what worked for me:
1. Right click ‘Computer’ then left click ‘Properties’ to open up System window.
2. Click ‘Device Manager’
3. Click ‘+’ on ‘Display Adapters’ and you should see the drivers for your video. Right click and select ‘Update Driver Software...’
4. Select ‘Browse my computer for driver software’ and click ‘next’.
5. Click ‘Let me pick from a list of device drivers on my computer’
6. Untick ‘Show compatible hardware’
7. Select ‘Intel Corporation’ then select ‘Intel 82865G’. Click next.
This will install the drivers. No they are not the same drivers for the hardware but they work a treat!
May 05, 2008 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX620 PC Desktop Logo
557 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
