Question about AppleWorks 6 for mac
I have apple works 6.0 on my older iMac. Is there
I have apple works 6.0 on my older iMac. Is there a way I can copy it to a cd, then install it on my my MacPro note book OS10.4.1?
  • Apple Master
  • 739 Answers
HI. When you opened up your new Mac and went through the setting up procedure it asked you if you wanted to transfer files from your old iMac. If you had said yes then AW would have transferred over OK.
If you still have your old imac then you can use Migration Assistant. It should allow you to do the transfer.
Once done you should update to AW 6.2.9
Posted on Aug 14, 2009
  • 101 Answers
Not really, If it was a legit copy when appleworks was installed it 'unpacked' all its information from a cd/dvd putting all the info it needed to run appleworks onto your mac and its unlikely the installer which isn't needed to run the software was copied over
Also your macbook uses a different O.S to your imac which would mean fiddling about changing the os settings.
Might be worth doing a search on your imac for .dmg
just type .dmg into your mac (not internet) search bar and let it search your mac, if there is an install file for appleworks this should find it
If you dont use appleworks for the database or drawing function maybe have a look at iWORK for you new mac
Sure you will love your new macbook though :)
Posted on Aug 02, 2009
    Sergeant:
    Champion:
  • 233 Answers
No, Its a copyright (r) cd. Which obviously means you can't copy it. And if you did it would be illegal. Im not accusing you or anything, I'm just giving my solution.
Sorry for an inconvenience...
Good Luck
How to replace solid state hard drive on imac computer
Hi Felix
Pretty simple really.... once you get the iMac opened!
See below
Simply find the existing hard drive, disconnect and slip it out.
You might have to remove a couple of screw in locating studs from the old drive and add to the new drive.
The connectors should match up with the existing cable.
Called SATA (Serial ATA)
The temperature sensor is stuck to the outside of the drive, carefully peel it off and stick it on the new drive.
Use Carbon Copy Cloner (CCC) to make a clone copy of your existing drive or install a new OS X (Downloadt off Apple Site)
Good Luck
I'll assume you know that Maverics, Yosemite OS X are free to download. And the latest El Capitan is due in Days.
Resources:
Mac Backup Software
intel iMac HD install
Sep 17, 2015 | Apple iMac 24" Desktop
I would like to know if an older hard drive from imac model A1076 could be installed in a slightly newer imac, model A1145 and have it be compatible and working with no problems?
Hard drives are universal, and based on physical connection / type. So your older HD should work even if you have newer SATA connection. The connection is backwards compatible.
Dec 08, 2012 | Apple Imac G5 20" Als G5 2.0ghz 2gb-ram...
IMac Missing operating system screen
The CD was most likely not burned in the correct way that Apple requires for OS installs. You can't just simple "copy" a system disk.
Try getting a hold of an actual legitimate copy of the OS and try again. This is not generally a problem when actual system disks are used.
Oct 22, 2012 | Apple iMac G5 Desktop
Trying to get an HP 1401 printer to work on an older imac G3 computer. Printer connects to USB port. Cannot find correct drivers qnd don't know how to install drivers on an apple imac.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11543&tmp_task=setupCategory&lc=en&dlc=en&cc=us&product=1103491&key=null&site=null
Nov 14, 2010 | Apple iMac G3 Desktop
Disk copy error on a macintosh, cannot download
Disk copy error is shown by PC when your CD have damaged or have many scratches. Sometimes, this problem occurs because of old or damaged CD/DVD Drive. Try to copy any other CD/DVD which have good condition. If it also not working check your CD/DVD drive to your dealer.
Jul 15, 2010 | Apple iMac G3 Desktop
Imac intel dual core dvd drive will not mountunable to load a cd or dvd it keep ejecting them. I have tried to boot with the OSX CD, but still it eject it out. I notice the problem when I tried to...
Installing Parallels should not change the way your optical drive works.
Try resetting the SMC as per the following article:
http://support.apple.com/kb/HT3964
If that doesn't work, try resetting the PRAM:
http://support.apple.com/kb/ht1379
If these do not resolve the issue you will likely need repair.
Jun 20, 2010 | Apple iMac Z0CY Desktop
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
May 21, 2010 | Apple iMac G5 Desktop
Blueberry iMac with slot-loading CD rom drive will
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website
http://support.apple.com/kb/HT3007?viewlocale=en_US as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Nov 12, 2009 | Apple iMac G3, G4 USB Keyboard 9224078
My iMac is not recognizing my CD/DVD-RW drive
Install your startup CD and restart the computer holding down the "C" if your computer starts off of it, the CD player is okay and you have a software problem, if does not start off the CD the CD/DVD needs to be replaced
Nov 28, 2008 | Apple iMac G4 Desktop
Using a MacBook as an external HD
Try reading here: Apple
Even though the article refers to Leopard, it should work for Tiger.
Here is the catch: The iMac needs a FireWire port
Mar 26, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
AppleWorks 6 for mac Logo
187 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
