Question about Craftsman 20 Hp 42" Deck Lawn Tractor
I can't disingage the lever to cut grass on my craftsman riding lawn mover. Now because of this I can't start the mover.
  • george recor May 11, 2010
    do you have pictures of it if so i can probably help
    Scholar:
  • 138 Answers
The lever moves an arm on the deck connected to a pivoting plate holding the idler pulley. when you push up the lever, it pulls the pivot [and idler pulley] back and puts tension on the belt. if this pivot gets rusted, it sticks and won't release tension on the belt. find the pivot point and lubricate it thoroughly with oil, wd-40, or liquid wrench, then work it back and forth by hand until it is freed up
Posted on Aug 25, 2009
Craftsman zts 7500 50" deck is there anyway to adjust height on this mower? at the highest level it cuts way to short and i have tons of grass blowing out the side cant hardly mow unless i mow about e
The range of the mover cut should be between 3-3/4" to 1-1/2".
If you are not getting these heights then the mover height mechanism may be jammed or broken. Use lubrication as instructed in the manual.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0803095.pdf
Sep 01, 2014 | Garden
Craftsman Lawn Tractor runs but does not cut grass?
Above deck, below tractor is black cable which has spring on end and goes to a tensioner pulley.
This cable should be locked into a bracket with a retainer pin and then its spring tip (rounded) goes around the top of tensioner pulley axle then a small washer on top and then retainer pin goes through this tensioner pulley axel shaft tip to hold spring onto it.
Jun 13, 2013 | Craftsman Garden
Craftsman riding lawn mower won t cut grass
Does it die when you attempt to engage the cutting deck? If so the you might have a clogged fuel filter, bad gas, dirty air filter, bad spark plug.
Or the mower engage switch may be faulty. They are located in different places on different mowers. But should be attached somewhere along the main pivot of the engage lever. Let me know if you need more assistance. Good Luck!!
Jun 05, 2012 | Craftsman Garden
Uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Sep 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do u get the blade going to cut grass
there should be a lever or switch that will make
blades turn..
Jul 02, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
May 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
120 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
