Question about Hoover Refrigerators
Our Hoover HSXS 5085 side-by-side stopped making icecubes and freezer temp rose to only - 5 deg C. Fridge side temp okay. Switched off & left doors open 2 days but that didn't help. Any suggestions?
3 Suggested Answers
SOURCE:
  • 531 Answers
SOURCE: Fridge worked perfect for 3yrs, one day i took
you may have a big problem not sopose have the door open so long better you call service
Posted on Apr 02, 2009
  • 106 Answers
SOURCE: Neither fridge nor freezer will keep cold. Motor
it proberbly has slow gas leakage get it toped up with gas and the leakage points must be traced and sealed
Posted on Jun 16, 2010
Bosch kgu3201 fridge freezer
Request a wiring diagram directly from Bosch.
Dec 14, 2017 | Refrigerators
I am having trouble getting new fridge cool enough in fridge. Should it get below 40 f in fridge on mid setting of both freezer and fridge section
fresh food tempt should be 38 deg ( this is good ) and 40 is close . as it will be 5 deg up and down freezer thempt should be around 5 to 15 deg or ice mker will not work . make sure the coils ore clean and fans are working or these tempt can not be obtained . mm feed back pls
Jan 01, 2011 | KitchenAid Architect Series II KSRG25FVMS...
Freezer section 26 deg f. refrigerator section 58 deg f with both dials set on 3. refrigerator section not cold even if dial is set to 4 or 5
when you open the freezer door do you hear the fan blowing,also is there any like snow or frost on the freezer wall inside the freezer,touch it and make sure or was the door left open?is there frozen water droplets on the food packages and on the racks,let me know what you find and send the model number,open the fridge door and look on the left side wall near the ceiling
Sep 07, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Temp problem. freezer temp 0 deg. fresh food 46 deg.
An hour aint enough. Turn off fridge, use blow drier, thers a huge ice cube behind that sheetmetal wall back of freezer inside wall, it takes 48 hours at 75 degrees to let it do itself. Listen for inside motor, its obvious. If so, you hve a defrost problem.
Mar 12, 2009 | Refrigerators
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Samsung r521jlmr
The sensor on that unit is probably near the door. This happens a lot on Walk in coolers/freezers also. As long as the temp goes back down in a few minutes, the unit is ok.
Jan 29, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
50 people viewed this question
Top Hoover Refrigerators Experts
Jon Tutas
Jon Tutas
Level 1 Expert
Steve F
 Russ Hill
Russ Hill
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
