Broke left side cd tray on my NuMark CDN25+G . where can I get parts?
    Brigadier General:
  • 8,619 Answers
Hi
Please click on the following links to get the parts for your Numark CDN25-G:
NuMark CDN25-G Parts(1)
NuMark CDN25-G Parts(2)
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Aug 02, 2009
Numark cdn450 has tray error message in left well
For all kind of brands cd or dvd players There is in every cd or dvd tray in the front bottom or under the tray so crazy you can not think an microswitch necessary that will be by mechanic close of the tray detect if the tray is closed and give a timed signal (close or open) to focus laser for reading of table of contents if the belt is bad it can take to long by a slipping tray drivebelt for the detection , or the microswitch or brass plate contacts are have a little corrosion on it or even it can be broken by a missing timing.
Dec 23, 2013 | Numark Industries Numark CDN450 Rack Mount...
Numark cdn25 dual cd player when open close the lcd screen gets dim
Are you using the original factory power supply? That sounds like it isn't strong enough. The mA is what I mean.
Feb 28, 2013 | Numark CDn25 Professional DJ CD Player
How to connect a numark cdn25+g
This should help:
http://www.numark.com/images/product_downloads/cdn25_quickstartguide.pdf
You do need an amp.and a mixer. You mixer should have microphone jacks, and a pream or switch to allow you to use lowZ, High Z or amplified microphones.
Mar 29, 2012 | Numark CDn25 Professional DJ CD Player
My newmark 2 dual cd has a jammed cd on the left side and will not eject
Look for a small whole below the tray on the face of the player that looks like you could stick a paper clip into and then stick one it it push firmly but slowly into whole and unlock tray.
May 06, 2011 | Nu Mark Numark Cd-Mix-2 Dual CD...
Cdn-24 cd door wont open
Often the cause is a jammed CD or aa little belt that drives the carriage has failed or is slipping.
You need the OPEN the case to retrieve the CD if one is in there and check the mechanism does not have a problem. Some drives used to have a SMALL hole near the door that one would insert a straightened paper clip into straight to press a release... You might check for that.
Feb 25, 2011 | Numark CDn25 Professional DJ CD Player
I like to buy the right side transport of my numark cdn95 player but i dont know where/
Your best bet is to contact Numark directly. I don't recall the optics used, but I think that this unit uses Sony optics. If the tray is not working correctly, it can be a belt or a mis-alignment. Ca you describe the problem you are having?
Dan
Jan 27, 2011 | Numark CDN95 2-Disc CD Player
CD DECKS FADER BROKE FOR NUMARK
This is a common replacement part available from Numark as well as some generic electronics suppliers. Any local shop that deals with audio equipment should be able to repair this for you. Expect a parts cost between $10-$20.
Dan
Nov 07, 2008 | Audio Players & Recorders
Cdn 36 pbm
unit needs internal cleaning. cleaning cd probably won't work.
Oct 27, 2008 | Nu Mark Numark Cdn36 Dual CD Player CD...
Numark CD mix 3 right cd door seldom opens
Defective load belt or defect in laser assembly
Sep 11, 2008 | Audio Players & Recorders
48 people viewed this question
 Grubhead
Grubhead
