Question about Blitzz Technology (BWA611) Router
I have a Netwave Base G4 wireless router w/ 4- port switch,trying to network two computers via cable modem using local ports,modem and router not communicating
    Genius:
  • 1,269 Answers
You need to change the LAN IP address of your router. Open the router's admin through http://192.168.1.1 and look for router's IP address or Local IP Address. Change it to 192.168.10.1 and save the settings. Reboot the router after that. If you are on cable internet , you need to do MAC Cloning. Access the router's admin page and look for MAC Clone settings. Enable and clone the PC's Mac Address. Save the settings and power cycle the router and the modem after that.
Posted on Aug 03, 2009
The router is saying there is no internet connection from the router to the modem.. Please help cause i have internet from modem to computer..
That means that the communication is cut from router to modem. You need to find out what is the problem.
1. check if the network cable from is still working or properly connected2. try a different ethernet cable or network cable from router to modem3. try some other dsl ports (yellow ports) at the back of your modem for ethernet cable connection to the router.4. switch ends of the cable you are using
these steps should fix the problem for if you are going to analyze, the line break comes between the router and modem and the only means of communication of your router and modem are cable, modem port (for the network cable) and router port (for the network cable) which means that the problem is within that point only. This should fix the issue.
Dec 28, 2011 | Linksys Wireless-G WRT54G Router
How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
-> STATION Client/ /CLIENT ' Local/Lan
or
INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
May 03, 2017 | TP-LINK TL-SF 1008 P 8-port 10/100 PoE...
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Bigpond have sent me my 4 port Wi-Fi modem thompson TG782T Home Network Gateway, now I am sitting here trying to figure out just where everything goes!!! I received a cd rom however I can't get it to work,...
Telephone wall-plate <---- 4-strand telephone-cord ---> telephone-port in modem
AC power from wall-plate to modem.
LAN port #1 <--- Ethernet cable --> network-port on desktop/laptop computer #1.
LAN port #2 <--- Ethernet cable --> network-port on desktop/laptop computer #2.
LAN port #3 <--- Ethernet cable --> network-port on desktop/laptop computer #3.
LAN port #4 <--- Ethernet cable --> network-port on desktop/laptop computer #4.
Configure the router's wireless adapter:
* set a SSID
* set an encryption-level, e.g., 'WPA'
* set a network password
Use the SSID/password to configure your wireless devices (iPod Touch, iPad, XBOX 360, etc.)
Nov 26, 2010 | Gateway Computers & Internet
I bought belkin g wireless modem ruter but they didn't give me CD . How can i install this and how can i use my wireless ruter please. Thank you.
Power-off your cable-modem (or DSL-modem).
Use an Ethernet cable to connect from the modem to the WAN port on your router.
Use another Ethernet cable to connect from one LAN port on your router to the network-port on your computer (desktop/laptop).
Turn the modem on.
Turn the router on.
Turn the computer on.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like:
Default Gateway . . . . . . . . . : 1234.678.0.1
Start Internet Explorer
Type http://1234.678.0.1
to access the web-server "inside" the router.
Run the Network Setup Wizard.
Run the Wireless Networking Setup Wizard,
to pick an SSID, an encryption-level (use 'WPA')
and to pick a network-password.
Now, you can disconnect the Ethernet cable from the computer, and try using the wireless-adapter inside your computer.
Sep 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Set up difficulties
You sure can. Start w/ the Comcast modem as long as it is NOT a USB type and hooks using a CAT-5 cable (regular network cable). Hook the comcast modem to the WAN port of the wireless router. On the back of the wireless router use the normal 1-4 extra LAN ports to hook other computers or the SD208 switch to it and other computers from there.
Word of advise if using Wireless Router, be sure to read manual and set a KEY for your network to secure it from unwanted outside use.
Apr 03, 2010 | Linksys SD208 8-Port Ethernet Switch...
DHCP problems for wired devices on my network
It sure sounds like the switch is not passing the DCHPDISCOVER packets through to the Apple Extreme.
Is the switch a NetGear Prosafe switch, or a GS608, or a different model?
If it's a managed switch (e.g. ProSafe) then you can connect to the switch's management UI and confirm that the default uplink port is set up for the port that connects to the Apple Extreme, and that it's set to forward DHCPDISCOVER packets to that port
If it's an unmanaged switch like the GS608, then it shouldn't matter which port you connect, but if your model has one port labeled "uplink" then you should be sure to use that port to connect to tha Apple Extreme.
One last thought -- have you replaced the cable that you're using between the switch and the Apple Extreme? You could test the network by first connecting your computer to the Extreme so it gets a valid lease, then unplug it and hook up the full network (computer -> switch -> Extreme) and see if you can still ping the router.
That's a bunch of thoughts, but may not be a solution yet. If these don't address the problem, post back with the model number of your Switch, and I'll go more in-depth.
Feb 12, 2010 | Apple Computers & Internet
Trying to hook up router. What is the wan for and the 4 inputs
The WAN port is the physical interface that provides input and output to and from the device that provides Wide Area Networking capability .. i.e. the modem that connects to your Internet Service Provider. The usual choices are a DSL modem, a cable modem or a Wired router or a wired switch.
The 4 other inputs are wired inputs and outputs for wired Local Area Network connections.
The WAN port normally connects to the Internet. It is not necessary to connect anything to the WAN port to have a network. But without one of the usual devices, you will not have access to the Internet.
The LAN ports connect to the network interface port on the individual computers that are part of the local network. One port connects to one computer.
A large system will have routers connected through the LAN ports to the WAN ports on sub routers and so forth.
Nov 25, 2009 | Dynex DX-E402 Router
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
I need to connect a real router with more ports to it 4-2 pcs
Connect the LAN port on the Barricade to the WAN port on your wireless router. The Barricade should be "plug-and-play",
i.e., no need to configure it. Similarly, the WAN port on the wireless-router is plug-and-play, so it should automatically get an IP-address from the Barricade.
Use an Ethernet cable to connect the network-port on your computer to one of the LAN ports on the router.
Then, start Internet Explorer, and connect to the web-server "inside" the router. Run the "Wired Network Setup Wizard", and then the "Wireless Network Setup Wizard". When you're done, then your "wireless" device(s) (iPod Touch, laptop, XBox360) should be able to make a wireless connection.
Note: no need for any CDs to "install" anything.
Sep 23, 2007 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
Blitzz Technology (BWA611) Router Logo
874 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
fred capra
fred capra
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
