Question about Roper RAS8445KQ Top Load Washer
The water is going out the drain and cannot fill up the tub.
The water runs and runs and never fills the tub. It is continually draining and so it never goes into the wash or rinse cycle.
    President:
  • 1,776 Answers
Check out the height of your drain. If the drain is too low, the water will drain right out of the tub. Check out the attached photo. Hope this helped and best wishes.
Posted on Aug 02, 2009
    New Friend:
  • 63 Answers
The drain solenoid valve may be jammed or have something stuck in it. Repair or replace it.
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Water keeps filling but will not start cycle.
The top load washer utilizes a pressure switch attached to a clear plastic hose. If the water fills the tub but will not stop filling you will need to remove the top panel and inspect the hose for obstructions. You may need to disconnect the tube flush it clean and make sure no foreign debris are in the connector on the pressure switch. If the tub will over fill, you may need to replace the pressure switch. If the water will not fill the tub and the water continues to run you need to check the drain pump. Is water exiting through the drain hose? If so the drain pump could be the problem.
Feb 23, 2011 | Washing Machines
Sometimes when I turn the washer on; it continues to run the water without filling the bowl. Seems like the washer thinks its in rinse mode.
Check your drain the drain hose must be higher that the tub or it will run down the drain.
It must be going down the drain or you would have water all over the floor If the water is coming in it has to go somwhere. In rinse cycle it should stay in the tub until the timer kicks it into drain and spin.
Sep 14, 2010 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire glws1233as1 water runs continually. seems like a valve is stuck open or something. water is draining as fast as it is filling up.
your drain hose or drain is too low causing water to siphon from the tub as fast as it runs in. raise or loop the drain hose higher than the highest level of the tub.
May 28, 2010 | Washing Machines
Water runs continuously tub never fills My Fisher & Paykel top loader keeps filling and draining at the same time. It never gets full of water. The hose is way higher than the machine, but still drains...
where is water draining into? have u got grey water hose attached to it?make sure u can see end of drain hose, put into bucket at lid level, if it still drains as it fills u have a faulty control module.please reply for more help
Apr 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
Wash tub does not fill - water continues to run but does not fill
Be sure that the drain hose is routed HIGHER than the console of the washer. There is no drain valve, but rather physics that keeps water in the machine..
Doc
Sep 18, 2009 | Kenmore 22422 Top Load Washer
Keeps filling with water, but draining at the same time!
be sure your drain is nearly to the top of the washer if it is you may need to try a siphon break
Apr 24, 2009 | Washing Machines
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
Tub fills only 1/2 full but water keeps running as if the tub is not full. If the water level is set to 1/2 or less, tub fills 1/2 full and begins to cycle. The water is running into the tub but not...
Check the drain hose to make sure you have a high loop, ie. make sure the drain hose loops above the height of the washer lid before going to the drain pipe.
Also make sure the drain hose is not going too far down into the drain pipe.
You may be getting a siphon effect.
Feb 20, 2009 | Admiral AAV7000A
Water just runs through tub
The problem you are experiencing is called "siphoning". Check the drain hose going into the standpipe (drain pipe). If the hose is shoved down in the standpipe too far, or if you've sealed the top of the standpipe where the hose goes into, you have created a vacuum and are causing the water to continuously drain. The drain line needs an air gap to prevent this problem. Pull the drain hose back out enough to allow an air gap and make sure you don't have anything covering the top of the standpipe. Hope this helps.
Jun 15, 2007 | Kenmore 22422 Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
99 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
