Question about Craftsman Garden
Will not start. Now hear a faint click when I turn the ignition.
My tractor was running and I turned it of to take a break. When I tried to start it again all I heard was a loud "click". Could this be the solenoid is bad? This is a 48" Sears Garden Tractor with a 25 hp Kohler engine. I believe there is current to the solenoid.
Check for voltage at starter whe turning key to start if you have 10 or more volts the starter is bad if you have around 4 volts try tapping on starter while in the start position on key may just be froze up.if you have no voltage at starter then the solenoid may be bad.
Posted on Aug 05, 2009
How to test a solenoid for a John Deere 115 Lawn Tractor with 42" deck?
http://www.greenpartstore.com/assets/images/instructions/2012/am138497_installation_instructions.pdf
John Deere Starter Solenoid Kit AM138497
First make sure the negative battery cable is making good contact on the frame or what ever part of the mower it is connected to. Make sure both battery cables are clean and not corroded and are tight. Then try to start the mower. If it works, fine. If not then you will bypass the solenoid and see if the starter turns the engine. To bypass the solenoid take a car jumper cable and connect one clamp to the terminal on the solenoid that goes to the battery ( see the diagrams in the links above) Turn the ignition switch to the on position. Take the other end of the same color of the jumper cable (say you'll use the red clamps) and touch the clamp to the other large terminal on the solenoid, which goes to the starter. If the starter turns the engine, then you know the starter is good and that the solenoid is bad. If the starter does not turn the engine then the starter is bad. make sure you DO NOT touch the jumper cable to the starter case or any other ground.
May 18, 2014 | John Deere Garden
Toro/Wheelhorse Tractor wont start
AS YOU HAVE CHANGED ALL OF THESE COMPONENTS TO NO AVAIL IT HAS TO BE A BREAK IN THE WIREING ITSELF, YOU WILL HAVE TO FOLLOW THE WIREING WITH A MULTI METER TO FIND WHERE THE POWER IS LOST.
May 02, 2012 | Echo Garden
Regarding a Craftsman garden tractor with a 23 hp V-Twin Intek OHV with electric start... was surging a while back, I cleaned the carb by removing the bottom screw only, some gunk came out and it ran fine...
Valve clearance should be set at .004". You should take your carburetor apart and really clean it thoroughly. I recommend getting some spray carburetor cleaner, and I recommend safety glasses. You should get it really clean and inspect all passages, holes and all non metal parts. As for the engine not turning, check that the blades have been disengaged, simple mistake people will often make at least once. If necessary check all safety switches.
I hope this gets you going again.
Aug 05, 2011 | Craftsman Garden
Won't start just clicks when i push the start button. When I push the start button I do hear a faint click in the selection ( color, white.etc.) button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Mar 05, 2011 | Kenmore Dryers
Hi, I have a husqvarnaq lawnmower CTH1711. When i turn ignition key, it does not make any attempt to start. Completely dead. Would one of the safet sensors be engaged/stuck preventing machine from...
do u hear a lite click when turn key on near carb? if so u have a good fuse from there i would check break switch and pto switch make sure pto is disenguaged.find break swt should have 4 terminals one set is open other is closed and reverses when push plunger. starter solinoid has 2 small terminals one gets hot when in start poss other goes throughground circuit via break, pto switch that term must be grounded for solinoid to work if good u have bad solinoid hope this helps
Aug 14, 2010 | Husqvarna Garden
I have had an electrical problem with this mower since ive had it. I have just changed the solenoid and switch and have looked at the wiring and switches all day and still nothing im getting power to the...
soliniod should have two small terminals one should get power when turn key to start position the other runs through ground curcuit which runs through break and pto switch most tractors wont start with out break switch working properly i would start with that first the i would go to pto switch. hope this helps
Aug 01, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
Engine starting problem
The battery still may be bad. The fact that it "warmed slightly when being charged" doesn't suggest it to be good - instead it could have high internal resistance in one or more cells. A battery with this failure still measures a good 12V until you put a load on it. I'd take the battery to a battery store, not a lawnmower dealer, and have it tested there with an actual battery tester. If it's bad, replace it. If it's good, then it's probably the solenoid and that means you'll have to replace the starter/solenoid assembly.
Jul 05, 2010 | Garden
Garden Logo
337 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
