Parts to hook to sink faucet - Washing Machines
    Sergeant:
  • 231 Answers
You have to remove the strainer from tap faucet, adapters for different threads at hardware store
Posted on Aug 02, 2009
Elkay kitchen faucet model lk7124 replace stem
ELKAY ' Strainers, Fittings + Other Accessories for the Home
www.elkay.com/strainers-fittings-other
Results 1 - 15 of 91 - CERAMIC LONG STEM SQ MNTG COLD. 45921C. Brass. Price pending ... CERAMIC SHORT STEM SQ MNTG HOT. 45924C. Brass.
ELKAY ' Stainless Steel Kitchen Sinks, Faucets, Cabinets ...
www.elkay.com/
Elkay is an American-owned and operated innovative manufacturer of stainless steelkitchen sinks, faucets, foodservice products, cabinets, drinking fountains ...
[PDF]SPECIFICATIONS
aitcheson-dc.com/files/2012/07/EL.LK2432.pdf
LK2433 Dual handle, concealed mount mixing faucet. Metal ... (101.6mm). ModelLK2433 ... Hi-Arc® Dual Handle Kitchen Faucets. Models ... Elkay warrants to the original consumer purchaser that the Elkay faucet pur- ... replacement parts (or if no longer available a comparable product) if the faucet ... METAL STEM.
Amazon.com: Elkay - Faucet Parts / Rough Plumbing: Tools ...
www.amazon.com > ... > Faucet Parts
Amazon.com, Inc.Results 1 - 24 of 921 - Elkay GOBG1118SS Dayton Kitchen Sink. by Elkay. $44.50 ...Elkay A51947R Replacement Diacore Cartridge with Brown Stem. by Elkay.
Elkay A51947R Replacement Diacore Cartridge with Brown ...
www.amazon.com/Elkay...Replacement.../B0033UX8...
Amazon.com, Inc
Jan 14, 2016 | Elkay Plumbing
Installed a new KWC Domo faucet and its leaking (alot) under the sink
Does if have a sprayer and is it still hooked up?
Aug 14, 2014 | Plumbing
Freuer faucet leaking
Contact Freuer faucet and get free replacement parts. I was even sent complete unit that I had to install.
Mar 21, 2014 | FREUER Faucets Countertop Sink Mount...
I replaced the kitchen sink and hooked everything up, I have water pressure to the faucet but when I turn on the water it just drips out. what's wrong here
Check to see that the cutoff valves under the sink are fully open. Also be sure that any shipping plugs or caps in the lines were removed prior to installation.
Apr 15, 2010 | Delta Model 300: Classic Single Handle...
I have a kitchen sink faucet that is leaking water from the back part of the faucet. There is a hole there and the faucet leaks water, when the water is on. Why is it doing this?
If it is a rusted hole get new faucet, but on many faucets that is where the Sprayer connects. Check for loose Sprayer hose at faucet under the sink.
Sep 14, 2009 | Plumbing
I have a new hose for my Grohe Euro Plus to replace a leaking old one. I have disconnected it from the water supply but now the ends of the the old hose will not fit through part connected to the sink...
There are 2 sets of nuts and washers underneath the faucet that holds the faucet in place. loosen them and the water lines (after turning the water off) faucet lifts off from the top of the sink. Replacement the the same, just in reverse. BE SURE TO USE TEFLON TAPE OR PLUMBERS PUTTY ON THE WATER LINE THREADS TO PREVENT COSTLY LEAKS.
Jun 20, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe pull out kitchen faucet the inner tube ripped
go to the store you bought it and see if they carry parts. if not , try the internet under grohe.com.
Jun 11, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Installing TL794DD bathroom faucet
All faucets install easily if you have the proper tools. Answer these questions first: 1. how many holes are their in the surface of your sink? Is there a faucet installed now? If yes, you may only need to remove that faucet and use the same feed lines under the sink to hook up the new one. Take your faucet to the hardware store and ask the plumbing clerk if the hook ups under the sink are different from what your new faucet appears to be compatible with. good luck
Jan 17, 2009 | Toto Clayton W/S BATH Faucet BRUSHED...
Kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Aug 27, 2008 | Danze D316440RBT Fairmont Two Handle Wall...
Just got the Haier hdt18pa portable dishwasher
You have to buy an adapter for the faucet that allows the hose to hook up. You an get it at any hardware store. It's easier to get a dishwasher installation kit and just hook it up permanently.
Jul 17, 2008 | Haier HDP18PA Stainless Steel...
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
