Question about MidiLand Audio Players & Recorders
Power not on
MLI-450 may have connected with wrong power cable...now does not seem to have power when using correct cable. Is there any hope?
Belling Id 450 slimline has no power to buttons! Fuse is fine power supply is fine! No response from any buttons pressed....help!!!!
make sure that the connections in the motherboard are connected to your switch cables running to the front and that they are in the correct position.
Sep 02, 2014 | Computers & Internet
Where can I get a driver for my MLi 691H speakers? I am running XP.
The humming noise could be a earth loop problem.
This is caused by having the speakers/sub woofer connected to one power point and the computer connected to a different power point.
To eliminate earth loop problems, connect both the speakers/sub woofer and computer to only one power point. Connect all your equipment to one power point using a power board.
Apr 12, 2012 | MidiLand MLI-699 Computer Speakers
My n64 turns on (has the power light on) and seems to all be plugged in correctly, but the screen just remains black. What have I done wrong?
Thank you for using FixYa
The best way to troubleshoot a problem is to go back to the basics
You checked that the power is on
now check to see the rca cables are connected on the correct plugs Yellow (VIDEO) RED and WHITE (AUDIO)
if the cables are plugged in, make sure that you are in the correct input mode on the TV
VIDEO1
VIDEO2
etc...
Jul 18, 2011 | Nintendo 64 Console
MLi-698 speaker: what voltage/wattage for the power supply?
Whatever is the voltage or MLi 698 Hi-Fi Sound Monitor ?
Mar 07, 2011 | MidiLand MLi 698 Computer Speakers
The tweeter of my mackie srm 450 V2 makes a quite loud noise (humm). this nois was there right from the beginning, and mackie told me, that this was usual....the older 450´s did not make this kind of...
The latest 450v2 include this metal portion 1 to isolate AC lines over IC's, metal part 2 is include in all versions, some technician remove them and that creates more hum at idle levels, by having both the latest 450v2's are the quietest of the v2's.
V1 did not use switching power supply, they use discrete circuit and that is why they are a bit quieter
Aug 04, 2010 | Mackie SRM-450 System
All cords are connected and intact, and the tv is on the correct video mode. No audio or video is evident, what's wrong?
use a HDMI cable, one cable -one connection (u can't screw that up).
hopes TV supports HDMI, and dont forget to turn the power on for the PS3
Apr 17, 2010 | Sony Playstation 3 (PS3) Console
MLI-699 Computer Speakers Power supply Please and Thanks
You could try CabletoGo.com. They usually have just about every replacement power supply available for sale or can guide you on where to purchase. Hope this helps.
Oct 16, 2009 | MidiLand MLI-699 Computer Speakers
I recently got a new computer & it has windows
If there is not a dedicated port for the sub, you are out of luck. Unless - the MLI sub can serve as the splitter
Jul 24, 2009 | MidiLand MLi 450 Computer Speakers
16 people viewed this question
Top MidiLand Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
