Question about Epson Stylus CX3200 All-In-One InkJet Printer
Not printing clearly even after cleaning the head
    President:
  • Epson Master
  • 990 Answers
Hello sir; Not only to clean the print head also the ink cell.;
turn power on, open the cover, the ink cartridge will move to the center, then UNPLUG power cord, now you can manually move the cartridge check the ink cell which ink cartridge allway seating, there should be have a lot ink stick, just remove it.
Posted on Aug 02, 2009
How can I clean the printhead of pixma ma800
Cleaning the Print Heads from Your Computer
The print head cleaning function allows you to clear up clogged print head nozzle. Perform print head cleaning if printing is faint or a specific color fails to print, even though there is enough ink.
The procedure for cleaning the print head is as follows:
Cleaning
  1. Open the printer driver setup window
  2. Click Cleaning on the Maintenance tab
    When the Print Head Cleaning dialog box opens, select the ink group for which cleaning is to be performed.
    Click Initial Check Items to display the items you need to check before performing cleaning.
  3. Execute cleaning
    Make sure that the machine is on and then click Execute.
    Print head cleaning starts.
  4. Complete cleaning
    The Nozzle Check dialog box opens after the confirmation message.
  5. Check the results
    To check whether the print quality has improved, click Print Check Pattern. To cancel the check process, click Cancel.
    If cleaning the head once does not resolve the print head problem, clean it once more
Nov 30, 2016 | Canon Office Equipment & Supplies
The ink is blurred and not printing all the colors
Hi, You could try cleaning the print heads with a damp paper towel. Gently dab at them until you see clear colors with no bleed. It's ok even to let the damp paper set on head for few minutes. Also clean the print area in printer. Then put cartridges back in printer and run a print head cleaning. You may have to run it a couple times.
this has worked for me unless of course a cartridge is empty of a color.
Good Luck to you, I know you can do it,
tina
Mar 26, 2014 | Kodak ESP C315 Wireless All-in-One Printer
I have an Epson RX680 the black and yellow ink are not printing after trying several print head cleanings and even replacing the cartridges (even though they were better then half full)
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 15, 2012 | Epson Stylus Photo RX680 Printer
No cyan on photo
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 16, 2012 | Canon PIXMA MP620 All-In-One InkJet...
No black even after cleanings
May 16, 2012 | Epson Stylus Photo 1280 InkJet Printer
My epson me 320 does not print even though it is not out of ink.
Jun 18, 2011 | Office Equipment & Supplies
Printer showing "check print cartridge" can't clear
Sometimes, the cartridge head gets damaged due to touching or cleaning manually with something,so the printer head will not recognise it even if there is enough ink in it.Try using another cartridge & see if it works or not.If not,your printer,print head might be dirty or faulty...for dirty clean it with a cotton swab with a cleaning solution very carefully.Faulty heads are costly to repair..I am afraid..
Sep 02, 2010 | HP PSC 1210 All-In-One InkJet Printer
Canon pixma mp600 print problem
Don waste your efforts & $, replace the print head is the best policy.
May 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Lines/streaks on paper even after deep cleaning and head alignment
Set the print head on a paper towel to dry, drying time will vary. ... Run a print head alignment and a regular cleaning followed by .... Normally you can clear up minor clogs and streaking by running the cleaning cycle found in .... After all the deep cleaning cycles I suspect I have now clogged ...
www.applefritter.com
Dec 06, 2009 | Canon BubbleJet i560 InkJet Printer
Cyan will not print
Try replacing the cartridge. Sometimes they do get clogged and won't clear no matter how many cleaning cycles you run.
....John
Mar 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
332 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
