Question about Refrigerators
Fridge cools short time and stops
Fridge cools short time after 14 seconds compressor stops
  • 286 Answers
Sounds like the condensor fan isnt running. I would replace the fan if thats the case. If the fan is running then you have a overload problem or a bad compressor
Posted on Aug 03, 2009
U-Line 75FF Bar refrigerator stopped cooling
it could be a problem start/run capacitor for the compressor or compressor failure
get a fridge technician in to test and get a quote
Most small fridges are cheaper to replace than repair
Jan 09, 2016 | U-Line Refrigerators
Refridgrator's compressor run for few seconds and stop. No cooling
That is called short cycling and caused by a defective start relay, overload, run capacitor, defective fan motor or defective compressor and of course it needs to be diagnosed to have the fridge cooling again
APPLIANCE 911
Dec 03, 2015 | Refrigerators
Hotpoint RLA64T fridge freezing up after new thermostat fitted
WHEN U TALK ABOUT THE THERMOSTAT U MEAN THE COLD CONTROL THERMOSTAT OR DEFROST TIMER THERMOSTAT? WHEN UR PROBLEM SOUNDS MORE LIKE THE DEFROST TERMINATOR OR BAD HEATING ELEMENT, LOCATED ON THE FREEZER EVAPORATOR COILS? IF ITS STAYING ON ALL THE TIME U HAVE A DEFROST ISSUE? OR BAD SEALS ON DOOR AND DIRTY COMPRESSOR
Aug 02, 2014 | Hotpoint Refrigerators
Fridge cycles on and off every few seconds
sounds like the compressor can't start. could be the compressor itself, or the capacitor that kicks it on
Nov 13, 2013 | Maytag Refrigerators
RS267LBSH The refrigerator stopped working. The technician came and replaced the compressor. It works for 1 1/2 month and failed again. He came the second time and replaced the evaporator. A month
your getting ripped off try the defrost timer sounds like it is getting stuck, it operates on a 24 hour basis cycling between defrost, and turning compressor on and fan to cool the fridge
Sep 02, 2012 | Samsung Refrigerators
Clicking, buzzing, compressor too hot, thawed out
Sounds like the compressor is in thermal overload. Let it cool down completely and meter the starting amperage on start to run. The compressor could be seized or it's windings could be shorted to ground (checking the resistance between the windings terminals on the compressor while unplugged will determine this.).
Jul 14, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge lights flashing on and off, and inadequate cooling
could be a few things. sounds like the compressor is going. put a thermometer in it and play with the temperature settings.might have a short somewhere.
May 24, 2009 | Victory URD-27-SBS Stainless Steel
Candy fridge freezer
it should come back after about 20 mins only and should cool back after about 10 mins.
i'm afraid the buzzing sound could be coming from your compressor which can not start. the over current relay is tripping off after 20 seconds to prevent the compressor from burning up.
i suggest to unplug the ref, let it cool for 1 day, re plug it after a day and observe the compressor if would run.
if the buzzing sound is still there and the unit is no longer cooling, then the compressor is not running.
check the relay of the compressor. it could just be the relay.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Whirlpool Conquest
hi thanks for the question when you say it short cycles that's the compressor relay trying to start the compressor i would replace the relay & overload at the compressor thanks the appliance doc
Sep 02, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
May 10, 2008 | Refrigerators
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
