Question about Refrigerators
This is a side by side refrigerator/freezer with water freezing on the bottom of the freezer as well as water pooling under the freezer area & seeping out the side and front of the freezer on the floor. We pulled out the refrigerator and saw no leaks where the tubing is connected. Is thare a pan under this refrigerator or some other area that this water is coming from. The ice maker is working well as is the in-door water service. How do I identify the problem? I have never emptied a water tray or anything like that and have no other problems with this refrigerator. There is also no frost or dampness on anything in the freezer other than the frozen pool of water at the very bottom of the freezer.
    Sergeant:
  • 259 Answers
Defrost wiring problem, defroster stuck on or timer not working properly , eventually wires may short out. Had this problem on my whirlpool
Posted on Aug 02, 2009
Water is leaking out of inside bottom vent of freezer and pooling and freezing on bottom under pull-out container unit.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
The refrigerator is not defrosting properly, and water is pooling under the fridge daily. In fact, water congregates in the bottom of the freezer side. What doesn't escape to below the fridge, freezes...
heatman101
Aug 31, 2010 | Jenn-Air JCD2389G Side by Side...
I have water comming out of the freezer at times and a pool below the bottom shelf.
You drain has frozen up probably because of a clog. Take the bottom door out and right at the rear bottom of the freezer back in the middle you sill see a drain. When the freezer goes in deefrost the frost will melt on the evaporaterr lines and must go down under the freezer yours does not and when the freezer comes on that water freezes. next time it defrost it heats that ice and the melted water come out the front of he door. clean that drain.
Jun 06, 2010 | Hotpoint HSS25GFP Side by Side...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water leaks out the left front. Water seems to pool and freeze in the bottom of the freezer. The leak is not alot but it never stops. Have checked for level have disconected the water and ice maker. Still...
You have a plugged up defrost drain. There should be a drain hole way in back of the freezer, at the bottom. (it should be behind the panel at the back of the freezer compartment) Use a turkey baster with warm water to flush it out until water runs out the hole into the defrost drain pan under the refrigerator.
Dec 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water leaking from freezer.
instead of ice maker heres a more common problem
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 15, 2008 | Frigidaire FRS26R4A Side by Side...
Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Dec 10, 2007 | GALAXY Microsystems 25.4 cu. ft....
Refrigerators Logo
194 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
