Question about Pinnacle Dazzle DVD Recorder
Cant put the amount of time to record - Pinnacle Dazzle DVD Recorder
Hi, had the same problem and found that when I connected the adapter device, I'd managed to ignore the "new hardware ready to be installed" message that windows was giving me in the a message bubble. So, try disconnecting and then re-connecting the adapter that connects to the computer, look for the bubble and click on it. That should install the device driver. Then when you connect your video camera it should let you put in a time. That's what worked for me, though I'm having other problems with video lagging audio 10 to 15 seconds. No fix yet on this.
Good luck
Posted on Aug 23, 2009
How to enter disc menu for finalizing dvd-r on philips dvdr3330H
The Disc Settings menu is accessed from the Disc Index Picture screen (so it's not as easily accessed as on other brands of DVD recorders). When you first put a recorded disc in the device, you'll see this index screen. At this point you need to press the UP arrow on the remote repeatedly until the disc content menu appears. This is a screen with the disc name, amount of recording time used and the date of the first recording. Then press the Right arrow button to get to the Disc Settings menu. Use the Down Arrow to reach the line that reads Finalise Disc. Then press OK and then press OK a second time to confirm the action.
The documentation for the DVDR3330H is available from Philips here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=hu&ctn=DVDR3330H/02 . See page 52 for the screen captures. The Finalise steps are on page 53.
I hope this helps.
Aug 19, 2012 | Philips DVDR3330H DVD Player/HDD Recorder
How much recordable time can be put onto the dictation feature of my player?
Hi mzmaddy33...
The time recording possible for your GoGear Vibe depends upon which one you have.
They make this model from 2GB to 32GB...
An example of a 2GB card;
The amount of recording time that a 2-GB SanDisk memory card will hold is 60 to 80 minutes.
Please take time to rate me 4 thumbs up
Sep 03, 2011 | Philips GoGear ViBE Digital Media Player
I added the wrong starting cash.and would like to know how to change it to the right amount
Changing the starting cash drawer count is not a simple procedure. You can clock the employee out. When asked for the drawer count, ignore what is in drawer and enter the incorrect starting amount. Then clock the employee back in and enter the correct starting amount.
If you wish to tidy up the records, go into time management and delete the first clockin record. Then edit the starting time of the second clockin to match the first record that you deleted.
B Mattern
sysadmin@ccybernet.com
Please return and give me a favorable rating if this helps or is of value to you.
Dec 24, 2010 | Pc America Restaurant Pro Express
When i click record it says insert a valid record time and i cant
Hi and welcome to Fixyah,
if your IDVDR do not allowed you to input any minutes, You need to go back to step number 1 and then click on the pull down arrow and then look and choose Dazzle DVC 100 then go back to step number 4 and then go ahead and click on small circle and put the valid time to record.
Feb 06, 2010 | Pinnacle Dazzle DVD Recorder
WHEN IT ASKS YOU TO SELECT AN "X" AMOUNT OF RECORDING TIME, IT WON'T EVEN LET ME CHANGE IT FROM ZERO, THEREFORE I AM NOT ABLE TO MOVE FORWARD THROUGH THE PROGRAM.... ALSO, WOULD IT BE POSSIBLE TO HOOK...
Open your IDVDR then do the advance mode. click next. On step number 1 click the pulldown arrow and then choose your dazzle device things, Now after you choose it go ahead and go to step number 4 and then check if the grayed out is now highlighted.Then put total time record.
Nov 09, 2009 | Pinnacle Dazzle DVD Recorder
Can not record dvd movie that is more than 103 minutes in length?
The solution is the quality settings on the DVD settings. On a 4.7Gb disk, 279 minutes at 24% quality, down to 70 minutes at best quality. Also, more will fit on the 8.5Gb DL disks. You can also use automatic quality, that will fit the video that you have compiled onto a disk, using the highest quality setting that will allow it to fit. An alternate method is to 'burn' to an image file on the HD, then use a program like 'DVDShrink' to fit on the disk.
Apr 13, 2009 | Pinnacle Dazzle DVD Recorder
Recording Late
Check your automatic clock setting. If it is on automatic, set it to manual, and set the date and time on the recorder. It may be picking up an unreliable time setting from a station that is not too accurate.
tom
Aug 26, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Help
1. Power ON the recorder, put a cassette tape into the slot. Select EXT 2 as source for the recording when you use an external device as source for the recording.
2.You will need to leave your cable/satellite boxON and tuned to the correct channel for proper recording to occur.
3.
Press z (RECORD) repeatedly to select the recording time length. The recording time can be extended anytime by pressing z (RECORD).
Here are the few possibilities to answer your question. Goodluck!!! let me know if this helps.. thanks
Jan 02, 2008 | Philips DVP3340V
Video length
hi you may be able to indeed BUT it depends on how much Memory your phone has.. Often the manufacturers say that the phone can record for a certain amount of time.. BUT this is usually with the MAXIMUM amount of Memory that CAN BE installed. You may find that the amount your phone has is insufficient? Can you "Upgrade" your Memory in your phone? Thats all I can think of
Aug 21, 2007 | Motorola Mobility E815
Pinnacle Dazzle DVD Recorder Logo
242 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Pavel Pranovich
Pavel Pranovich
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
