Nothing is else the power is not turning off or on
SOURCE: Lexmark Fax/Photocopier/Scanner Model X5470
most likely it's just sending them to a file. Check the settings for this. You have the user manual?
check your computers warranty here 4 FREE
SOURCE: washer powers down during wash cycles
It is most likely a very slow fill problem ,either the cold or hot water supply is restricted and the machine cannot sense the right water temp. and will shut down .
Machine cannot wash properly with a small amount of water.
Ckeck ,the screens in the water valve or at the hoses at the top where the faucets are ,clean them or replace them but never leave them out .
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
SOURCE: how do i connect my lexmark x5470 with out cd software
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if
you get in troubles, follow
the instructions below to reset and reinstall drivers:
SOURCE: My lexmark x5470 will not turn on after disconnect
Is the USB cable back in place? Try holding down the #9 button and the select button while you are powering up the unit. If that fails try pressing the select button after powering up the unit. I had a HP all in one 7170 and during a WILD lightning show I got hit through the phoneline. Zap "All Gone!" I called HP support and they gave me these two steps to try, hope one works for you, if not it's time to go shoppin.
Try to rebrick you printer by pulling out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds. This will reset your printer.
If that doesn't help, try to plug your printer into a different known working power outlet.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
