Question about Homelite Mighty Lite Lawn Trimmer
Trimmer won't stay running
I prime it , full choke it, half choke it, it starts, and then when I go to run it quits after about 10 sec.
Too, it seems to just have one speed. Full out. If I use the trigger for gas it starves and quits.
  • hail2thevict May 11, 2010
    I have the exact same problem and this is only a few months old!
  • Homelite Master
  • 1,169 Answers
Most likely needs the carb rebuilt.
First check the prime bulb and fuel lines for cracks. Check the spark arrestor for carbon buildup.
Another problem could be a stuck piston ring, but try rebuilding the carb first as it is usually the source of the problem.
Posted on Aug 24, 2009
Trimmer has to stay between half choke and full choke to stay running what is it
Start with carb adjustment. One full turn out on both low and high side, then set the idle. If this doesn't fix it, then rebuild the carb.
Aug 26, 2014 | Ryobi Garden
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
What does the symbols mean on the controls
the on off switch has a o and a I The o is off and the other is on
as for the other three you have a from right to left on the main body full chock the half chock the run prime it 7 times on the primer ball with the full choke on the pull crank cable 3 times then move choke to half choke then pull until it starts if after 10 pulls it doest start out back to full choke and sart again if and when it startes let it rund for about 15 secs on half choke then move to run If after all that and you have done it a few times and it still doesnt start get rid of it as it is a totally rubbish tool I know i had one for 6 m onths used iit 3 times then i bought a stihl.
May 30, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Hard start tb475ss troy built weed wacker when i close the cold start lever it starts but its 75 degrees out its like the primer ball is inop but i see fuel moving through the lines when priming did not...
These 4 cycle trimmers need to be primed 10x before a cold start. The bulb will feel *firmer* on the last two or three depressions and you'll know that the carb is primed.
Full choke and and full throttle on first tug should see it hit once with a puff of smoke. Second start attempt should be in choke position two (half choke) and with full pressure on the throttle. Should rev to life on start attempt. Let the engine IDLE for 30 seconds, moving the choke to off at the end of the waiting period. Let engine idle to warm another full minute with no choke, then set to work!
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Husgvarna string trimmer stahls.
Try getting some carb and choke cleaner and spraying down the carb. You might have some varnish in the carb and it won't let the fuel flow properly. My ryobi 4 cycle trimmer does that every year. I clean the carb and it usually runs decently.
Good luck
roundo4
Aug 09, 2009 | Garden
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
My straight shaft trimmer will idle but dies when the I pull the trigger.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Homelite Mighty Lite Lawn Trimmer  Logo
612 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
