Question about Whirlpool Washing Machines
My washer is leaking what looks like gear oil. It is an Imperial Series type 111
  • 213 Answers
SOURCE: Kenmore 70 series Model: 22702 100 Series CL2738136 Type 111 will not hold water
the drain pipe in the wall needs to be as tall as the cabnet of the washer. if it is the see how much hose is going into the drain pipe. should only be about 9 to 12 inches into the pipe. any more than that will cause a syphon and suck the water out as it fills
Posted on Nov 27, 2007
SolutionGuy
  • 331 Answers
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
Posted on May 02, 2009
jmgldsmth
  • 2005 Answers
SOURCE: leaking tub on whirlpool washer
replace the main (under tub) seal
Posted on May 04, 2009
  • 24 Answers
SOURCE: My Kenmore Washer series 80 type 111 won't spin.
sounds as if it needs new brushes in the motor. don't use untill checked
Posted on Aug 05, 2009
  • 1937 Answers
SOURCE: it is a door switch for Kenmore 80 series top load
I'm not sure what your question is but following is the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.25842400
If you look in the top and cabinet section, you'll see a description of the Lid Switch.
If you need to replace it, you'll have to remove the cabinet first.
Following is a site with a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=534500897c8bf705d91c620362438f0e
Posted on Nov 01, 2009
Oil leak 2000 alero, just replaced plug, not it, leaked out all the oil after I drove it 20 miles, please help, could it be a gasket or what
Check the oil filter. The old gasket might be stuck on the engine (two gaskets stuck together), or the new gasket might be defective, misaligned or missing.
Nov 05, 2011 | 2000 Oldsmobile Alero
Washer Kenmore 70 Series Model # 110.247323000 Serial# CR3845255 Type 111 Washer fills cold, warm, hot - no agitation - no draining
IF THE MOTOR DOES NOT RUN CHECK THE LID SWITCH. IF YOU HEAR IT RUNNING YOU MAY HAVE A BAD COUPLER.
Jan 12, 2010 | Kenmore Washing Machines
I have kenmore washer ser#cs3726779 type 111 and it won't spin and has an oil leak uner it--can it be fixed economically or not?
if this is an older machine, it may not be cost effective. This sounds like the transmission is leaking and it will eventually fail.
Aug 29, 2009 | Kenmore Washing Machines
Thick Gear-like oil leaking from the bottom somewhere
looks like your washer is developing a leak from the seals in the drum thus allowing some water to seep into the bearings get it checked before the bearings run out completely
Jul 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Leaking oil
The transmission or, gear box housing is compromised. it has cracked for some reason. you will need to replace the transmission in this case.
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Washer Model:LSN1000KQ0,SER: CM4267948, Type: 111 - Need nylon gear in transmission gearbox.
From the information provided, it sounds like you need WPL 285362 (gear and pinion kit) which you can find at appliancehelp.com for $59.95. You can type in your washer model and see the diagram of each part before ordering so you get exactly what you need.
Apr 16, 2009 | Whirlpool Clothes Washer Timer Knob -...
Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
Mar 27, 2009 | Kenmore 24032\24036 Top Load Washer
2008 Yahama 90 2 stroke outboard lower unit fluid leak
Ok by fluid I assume it is gear oil leaking yes?
There is every chance there is the smallest seal leak there that may only be present once the gear case gets a little pressure in it, either through use, or through expansion as the leg heats sitting in the sun even. Have you got a new washer installed under this screw to properly seal it? Usually a nylon type washer is best.
Also, how do you know the lower unit is not leaking or have water intrusion? Have you drained the gearbox oil recently? If so what color was the oil, milky looking at oil or good semi-transparent oil color?
Mar 16, 2009 | Boating
Washing Machines Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal De
