Question about Conair HC221CS
Hc221cs the clipper blade came off and i can't get it back on how do i get the blade to go back on
  • Anonymous Feb 18, 2008
    We're stumped too. Will post if we figure it out.
  • Anonymous Jan 05, 2009
    my blades came out when I went to pull off one of the guards. Have not been able to get it back in, I am going to try bending the metal "hooks" so that the plastic hooks on the blade contraption fit into it
There are two mettle "hooks" in the main body of the unit. I bent those up a bit so that the plastic tabs on the head could snap back in underneath the "hooks".
Posted on Feb 21, 2008
Blade won't snap back on
make sure the clipper is running when you try to snap the blade on.
Dec 08, 2015 | Wahl 8786451A Arco SE Pet Clipper
Andis clippers are shaking and loud
sometimes it is the blade and not the clipper
Jun 20, 2012 | Andis Agc Super 2-speed Clipper...
Clippers stopped clipping. I changed to a new blade but it didnt help. I took the clippers apart and put in a new holder for the clippers. I put the clippers back together and although they clip a little...
Sound as though the blade drive needs replacing, commonly you will notice tram lines in the cut on your longer blades or the shorter blades struggling to cut
Jul 05, 2011 | Andis AGC2 Hair Trimmer
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to:
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
Blades fell off oster dog clippers but can't fit them back on. Please help !!
Assuming that you did not damage anything, the blades should go back on easily.
Slide the blade onto the hinged flat 'post'. Turn the clipper on. Fold closed the blade assembly into position against the clipper body.
If this does not ork, you must have damaged something.
Mar 27, 2010 | Oster Golden A5 2-Speed Universal Motor...
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
Mar 21, 2010 | Oster 76974-160 Hair Trimmer
How do you change blades on Wahl's clippers? Have new blades dont know how to replace them.
No problem look at your clipper blade, you will see 3 screws remove the screw in the middle ONLY, The clipper blade will come off, replace with new blade put back the middle screw on and tighten.
Mar 14, 2010 | Wahl Designer 6 (8355100)
Blade replacement
the lever on the clippers locates into the cutter of the clipper blade its only a matter of lining the lever up with the slot in the top blade which you can slide from side to side by hand. Please keep in mind wear on this plastic Drive Lever may lead to cutting problems.
Apr 22, 2009 | Oster 76076-010 Hair Trimmer
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
Putting blade back on my Andis dog clipper
It sounds like you may have a bent hinge which is what the blade slides onto. Please call Andis customer service at 1-800-558-9441 to speak with a customer service rep. They can give you instructions on where to purchase a new hinge or send or clippers in for repair.
Thank you,
Jun 17, 2008 | Andis 29745 Clipper Headliner Hair Trimmer
Conair HC221CS Logo
119 people viewed this question
Top Conair Health & Beauty Experts
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
