To solve this problem you should see on your keyboard a FN key by the windows key this key activates the secondary mode of your keyboard it has to be held down for this mode to stay on as soon as you let go of the keyboard returns to normal you should also noticed that F1-F12 have differentsymbol'son the keys one of them should transfers the display to you externalmonitor to get it to go back jut repeat the above steps hope this helps
Be sure to have latest driver for your external monitor or check if there is a task in the task scheduler called TMM (Microsoft
Transient Multi-Monitor Manager). disable it. Or use NVidia panel if installed on your system.
The problem is not with the windows vista , but the problem seems like the graphics driver.Restart your computer and press F12 a couple of times before windows loads. You should see Boot menu screen.
Now toggle the display to the external monitor, by pressing the FN+ F8 . if the display toggles the video port is fine, if not then you need get the video card checked. If the display is there. Restart your computer , and try reloading your graphics card drivers.
Thanks for using Fixya
proton
Was this helpful?
Yes
No
Popular Solutions for HP Compaq Evo Notebook N1000c
hp pavilion m8070uk pc - on power up no display and gives 1 short and 1 long beep. Recently seen...
(More)
hp pavilion m8070uk pc - on power up no display and gives 1 short and 1 long beep. Recently seen error regarding hard disk failure imminent and recommended backup - which was done. PC would start but started freezing and need continually rebooting. Now it wont even start up - is this a motherboard problem?
I have a Medion Akoya notebook, which i purchased new about 8 months ago. I was using my laptop...
(More)
I have a Medion Akoya notebook, which i purchased new about 8 months ago. I was using my laptop without mainspower and it eventually shut down. When i plugged in ac power the brightness of the screen remained low. I tried manually adjusting, ie Fn F4 F5 but it shows brightness at full. I tried adjusting power settings from control panel with no joy. Have also tried going into display properties advance settings for video card and tried adjusting gamma, brightness, contrasting. whilst this adjusts colours etc but cannot seem to configure the same settings that where there before. I think the video card is called, Plug and Play monitor on mobile Intel(R)945 express chipset family. Can anybody help??
A got a Laptop Winbook 330. 1 G ram memory 100 g HDD Celeron 1.5 OS had problems so I insalled a new...
(More)
A got a Laptop Winbook 330. 1 G ram memory 100 g HDD Celeron 1.5 OS had problems so I insalled a new one. Now im having problems to find the drivers for the audio and wireless connection.
do you sell spares for md612ouk .the reason i ask is that i can buy a display module with parts...
(More)
DO YOU SELL SPARES FOR MD612OUK .THE REASON I ASK IS THAT I CAN BUY A DISPLAY MODULE WITH PARTS MISSING
