My Singer 7462, when turned on panel lights flash continuously and there is a long beep sound. Tried the reset and cleaning/rethreading procedures but no success. Any ideas?
My brother LS 1217 sewing machine under thread is very loose. I tried all options like adjusting the wheels, tension, rethreading and played with the machine. No use.
Your machine needs to go to dealer to rectify the problem. Your machine sensors are telling the machine that the needle bar is not idle while winding the bobbin and the flashing lights is a warning message. Nothing serious and your dealer should be able to fix it in 30 minutes. You need to remove the covers and hand wheel, so best to leave it to the experts
Ok, this is pretty common. Disengage the machine (as if you were winding a bobbin) run the machine at high speed for 5 minutes. The motor is dirty and this will clean it out. You should hear the pitch of the motor change as the minutes go by.
Sounds like you may have a blockage somewhere in the bobbin area that needs cleaning as this is normally what happens when it gets jammed. Reverse sewing can sometimes cause jams. Remove bobbin area and reassemble.
Sounds like there is thread around the bobbin winder shaft and the machine is unable to continue winding, needs stripping and looking at. This is not something you should attempt yourself unless you know what you are doing. A reasonable sewing machine tech should be able to sort it out in a few minutes.
