Question about Epson Stylus C86 InkJet Printer
Print pattern is broken and not all colors showing after repeated head cleaning
  • 36 Answers
It sounds like you're out of ink. If not, going through the alignment procedure for your printer might help.
Posted on Aug 02, 2009
How do i remove and clean the printhead from a canon pixma mp780?
Hi there. i understand that you want to clean the printhead of your canon pixma mp780, dont worry im here to help you out with this.
do this following steps in order for you to clean the printhead.If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Take Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary ok?
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
hope that this steps helped you a lot in cleaning the printhead of your printer.Good Luck!
May 30, 2011 | Office Equipment & Supplies
My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
Do the following to clean the print head:
1. Press INK key on the control panel.
2. Press the DOWN arrow key until CLEANING appears on the LCD.
3. Press OK.
4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
5. Press OK.
The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
Do the following to print a Print Quality Check Sheet:
1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
2. Press OK. PRINT QUALITY will appear on the LCD.
3. Press OK.
4. Press COLOR START.
NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
Streaks on copy
Try these steps first:
1. Check ink level.
2. Nozzle Check Pattern
  1. Load A4- or letter-size plain paper in the Auto Sheet Feeder (ASF) or cassette.
  2. Press the <Feed Switch> button to select the appropriate paper source.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Press <OK>.
    The machine prints a nozzle check pattern.
  5. Confirm the pattern is not broken, missing, or a specific color is not printed.
3. Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
You can also try using a higher quality print settings as follows:
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
If the above steps do not solve your problem, it may be a time to purchase a new printhead.
Oct 09, 2009 | Canon PIXMA MP750 All-In-One InkJet...
I HAVE A CANON MP 760 PRINTER THE MAGENTA COLOUR LINE IS TWO TONED WITH DARK AND LIGHT PINK . SO WHEN PRINTING PICTURES THERE IS DISTINCT LINES CAN SOMEBODY HELP HAVE TRIED THE CLEANSING REPLACED THE...
You need to conduct the following steps:
The nozzle check pattern shows if each print head nozzle is operating properly.
You can also print the nozzle check pattern from your computer.
  2. Press <Feed Switch> button to select the paper source.
  3. In either COPY, PHOTO, or FILM menu screen, press <Menu> button.
  4. Press the left or right arrow to select [Maintenance/Settings], then press <OK>.
  5. Use left or right arrow to select [Maintenance] and press <OK>.
  6. Use up or down arrow to select [Nozzle Check] and press <OK>.
  7. When prompted to print a nozzle check pattern, use the up arrow to select [Yes] and then press <OK>.
If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head.
MEMO:
a. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
b. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
  1. In either COPY, PHOTO, or FILM menu screen, press <Menu> button.
  2. Press the left or right arrow to select [Maintenance/Settings], then press <OK>.
  3. Use left or right arrow to select [Maintenance] and press <OK>.
  4. Use up or down arrow to select [Print Head Cleaning] or [Head Deep Cleaning] as necessary and then press <OK>.
When prompted to clean the print head, use the up arrow to select [Yes and then press <OK>.
IMPORTANT:
If normal print head cleaning does not improve print quality, perform deep print head cleaning.
Print Head Alignment in Windows
If colors mix or streaks appear in the nozzle check pattern, perform the print head alignment.
The print head alignment can be performed either automatically or manually.
If the automatic print head alignment does not resolve the problem, perform the print head alignment manually.
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Aug 09, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Printer prints same goobly gook over and over how do i clear
Solution: Perform the print head cleaning procedure MP750 / MP780
Now if you mean not printing the letters correctly go to this site and download the drivers and reinstall them. Also you will find manuals on HOW TO sort of thing:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10444#DownloadDetailAct
hope this helped, please leave rating
May 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
The 3eBK head stopped printing.
Try below some steps which might help you resolve the problem.
If this does not help, try removing the print head and then install it again. Once place, dont forget to aligh the head. Following are the steps:
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
    Handle ink tanks carefully to avoid staining clothing or the surrounding area.
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
    IMPORTANT:
    a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
    b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
  9. Close the Inner Cover 2.
  10. Close the Inner Cover 1.
  11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
Automatically Aligning The Print Head Position:
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
Manually Aligning The Print Head Position:
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    (1): Bad example (Least solid box)
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
    (0): Select pattern number with most solid image
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Can you help? After changing the cartridges, I keep getting a message about the ink head being incorrect...I am directed to press 'OK' which does not help; then to turn printer off and on again, which...
Cleaning your head might resolve your problem. Perform the below steps to clean the head:
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head (Cleaning) or print head deep cleaning (Deep Cleaning). Note:
  1. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
  2. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
Overview:
Step1:
Print the Nozzle Check Pattern.
To check whether the print head nozzles are clogged, print the Nozzle Check Pattern.
downicon.gif If the print quality is poor, perform print head cleaning.
Step 2:
Perform print head cleaning.
This unclogs the print head nozzles
Print the Nozzle Check Pattern again.
If the print quality is still poor, perform two print head cleanings.
downicon.gif Print the Nozzle Check Pattern again.
Step 3:
Perform deep print head cleaning.
This is a more powerful cleaning.
Displaying the Maintenance screen
  1. Ensure that the printer is powered on.
  2. Press the <Menu> button.
  3. Press the left or right cursor to select [Maintenance/settings], then press <OK>.
  4. Press the left or right cursor to select [Maintenance], then press <OK>.
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer update
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head. NOTE:
  1. Press <COPY> or <PHOTO>.
  2. Press <Menu> repeatedly until <USER DATA> appears.
  3. Press < (left arrow) or > (right arrow) to select [MAINTENANCE].
  4. Press <OK>.
  5. Use < or > to select [CLEANING] or [HEAD REFRESHIN] as necessary.
    [CLEANING]: Performs normal print head cleaning.
    [HEAD REFRESHIN]: Performs deep print head cleaning.
  6. Press <OK>.
  7. Print a Nozzle Check Pattern to see if print quality improved.
    4. Press <OK>.
    5. Press <OK> again.
      The machine prints a nozzle check pattern (A).
  8. If broken or white lines appear in the pattern, perform two Head Refreshings (from steps 1 through 6) then print another Nozzle Check Pattern.
  9. If print quality does not improve after two Head Refreshings, replace the appropriate ink tank.
Confirming The Nozzle Check Pattern
Broken lines
sj402061.jpg White lines
sj402062.jpg Click here to return to step x to perform Head Refreshings
Oct 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Epson Stylus C86 InkJet Printer Logo
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
