Question about Vizio VO47L 47 in. LCD TV
Our VX42L display goes black after an hour use but has sound
After a half hour to two hours use our display, using HDMI, will become garbled for a fraction of a second and then go black, but still has sound. We have tried other inputs with similar results. After turning off, unpluging the TV, and waiting a few minutes, we can then plug in the TV and turn it back on with a normal picture--this only lasts for a few minutes before picture loss repeats.
This is NOT a problem with the backlight as we can obviously see some light seepage when the LCD is polorized during failure. This is NOT a problem with the LCD array as there are no defects during initial operation. This IS a problem with one of the boards inside the TV.
Does anyone know witch board/component is causing this intermitent failure once the temperature has obviously warmed up from use?
  • bryankeithfl Aug 02, 2009
    We have verified there is no problem with the backlight as the very bright light from the CCF panel is coming out the vents in the top and back of the TV the same as when it displays a picture.
    We have power cycled the television during cool down by unpluging it and pressing the PWR button for 60 seconds to deplete any electricity stored.
    We are looking at replacing Main Board 3647, but would like positive or negative feedback and any other suggestions about simple fixes before spending $140.
    There are no firmware updates available for the VX42L 10A LCD unit at this time. Yes, we just absolutely love DRM too...
    We have seen the same display problem on RCA composite inputs as we have on the HDMI inputs, and with no new firmware downloads, for now we have ruled out DRM issues.
  • 36 Answers
I would check to see if there are any firmware updates for your tv on Vizio's website. This usually involves downloading the update onto a usb stick and turning the tv on with the usb stick in the tv's usb port.
Before picture/sound is shown on the tv, the source and tv talk to each other over HDMI to make sure there's no piracy going on (don't you just love DRM?). If the source gets a strange response or doesn't get a response fast enough, it may assume that something illegal is going on and cut the connection to the tv.
Posted on Aug 02, 2009
Benq w1000 projector
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 07, 2014 | Office Equipment & Supplies
Jvc pd-z42dv4 screen goes black after approx half and hour. Can this be repaired?
Usually a few electrolytic capacitors on the power supply board are swollen or burst.
Dec 17, 2013 | JVC PD-42V475 42 in. HD-Ready Plasma...
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
Programing
You posted under Leviton 6124 programmable timer.
If this is not your timer, add a comment
Leviton 6124 manual:
http://waterheatertimer.org/images/6124-manual.pdf
If you have different timer, look at link below to help identify timer.
Leviton Timers:
http://waterheatertimer.org/Leviton-timers.html
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Dec 02, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Hitachi 50" hd TV displaying black lines on screen
Sounds like your YBL-Y Buffer lower board is going out. There are 3 boards here. The Y buffer upper which controls the top half of the display, The Y buffer lower controls the bottom half and the Y-SUS main control those two boards. They work in unison. Usually if one goes out you have to replace all. You can also get lucky and just repalce the YBL and all may be well. Now if they are vertical lines up and down the OSD-On screen display, then this is indicitive on dry solder joints on the D, G E, F boards. Hope this helps...
Jun 29, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Decora 6124H Timer
Jan 04, 2010 | Leviton 6124H 24 Hour LCD Programmable...
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
Top half of screen goes black
Sounds like your having problems with your Y-main(upper buffer) is getting too hot. The IC's located on this board are really bad about going out a lot. If you take the back cover off your Plasma. U will see that the manufacture of the panel is Samsung and the panel model is probably S42AX-YB01. you should be able to purchase the board. probably will run about $ 150.00.
Hope this helps
Mar 20, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Lg 50inch tv(lg50px4d-eb
I've been finding quite a few HDMI related problems over the past year and it seems to be increasing. The problem usually is due to the cable being somewhat heavy. The plug sticks straight in and hangs. The weight of the cable uses the downward momentum and starts ripping the solder connections from the televisions HDMI input. When the audio becomes distorted, try moving the cable and see if it clears up. If it does, then, that's the problem. If not, then the problem is more than likely the audio circuit. Either way the Main PCB needs to be replaced. After replacing the Main board, I suggest using component inputs instead (Same quality picture, just more cords), because, the chances of another problem caused by HDMI is likely. Hope this helps.
Apr 08, 2007 | LG 50PX4DR 50 in. Plasma TV
Vizio VO47L 47 in. LCD TV Logo
417 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
