Question about Optical Coating Model 108 VHS VCR
Vcr a tape is stuck in my vcr how do i get it out of there.
  • Anonymous Dec 17, 2007
    I can not eject the vhs tape that is in my tv. I have tried everything with no luck. does anyone know how to get this tape to eject??
  • 3 Answers
You might have to take the VCR apart. Depending on how old the model is, you might just need a simple Phillips Screwdriver to open it. After you open it there should be a shielding case or something to keep static from disrupting the reader head. After you take the shielding off you should be able to see where the tape is stuck and you can pry it that way. Then put the thing back together.
At least that's how the old models do it. The new ones might be a little hard to get into.
Good luck.
Posted on Jun 16, 2009
VCR tape won't eject
The reason your tape wont eject is either because, it is stuck or the tape run loose inside of it.
To remove the tape, unplug the VCR, then unscrew it open, you will have direct access to the tape, so try to plug it back and press eject, when it gets stuck, apply a little force in pushing the tape up, to the height where it is to pass out, and it will eject your tape.
If you are not familiar with such activities, i will advice you get a repairman to get this done for you, in order for you not to damage any other part inside the VCR.
Take cacre and good luck
Oct 14, 2010 | Sylvania LV448HG VCR
VCR tape stuck in VCR
One way is to take off the cover of the unit so that you can see where the tape is hung up and help push the tape out. (One of two problems are usually involved: the cassette cover isn't closing down evenly (a high corner blocking the travel path) or a loop of the tape blocking the cover closing.)
On my VCR unit it was ~4 screws on the back that held the cover in place. (That was VCR only. There might be a few more screws in the larger unit.)
I hope this helps.
Jun 06, 2010 | Samsung DVD-V3500 DVD Player/VCR
Had a stuck tape its gone now but still having trouble.
The tape is stuck in the vcr and doesn't get released. How can I remove it?
Aug 15, 2009 | Emerson EWV601 S-VHS VCR
GE vcr tape stuck
when this happens to me, i disconnect the vcr and remove the screws to the top cover. i remove the cover and carefully remove the tape, being careful not to touch any of the parts of the vcr. but please make sure the vcr is un plugged.
Dec 08, 2008 | GE VG4052 VCR
VCR tape went in backwards now its stuck please help. Thank you in advance ;-}
You will have to unplug the VCR and take it apart. You should be able to move the mchanism and/or door to free the tape.
Sep 07, 2008 | Sony RDR-VX515 DVD Recorder/VCR
Tape stuck in vcr
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
Jul 10, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Mar 02, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit." unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it." unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Televison & Video Logo
104 people viewed this question
Top Optical Coating Televison & Video Experts
Are you an Optical Coating Televison and Video Expert? Answer questions, earn points and help others
