NEC LTY260K Lamp won't light every time. After turning power off for one full minute the lamp works again. What is causing this problem?
  • 167 Answers
The lamp is getting weak. You should never unplug on these type TV's as they must have power all the time.When you power down the TV, there are fans that run for several minutes to cool down the lamp. If the lamp is not allowed to cool properly, then it reduces the life of the lamp.A battery back-up is the best solution.
Posted on Aug 03, 2009
NEC vt800 projector troubleshooting
That is a problem with the lamp. Replace it with a known good one.
Feb 27, 2013 | NEC VT800 LCD Projector
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
Help statius orange light 6 times lamp error try again in a minute. Still not working???!!! Help
Is the lamp and cooling pump covers on properly. It is saying that there is a lamp failure. Do you hear the high voltage trying to start the lamp when it turns on
Jun 30, 2011 | NEC NP60 Projector
I just bought a used NEC Multisync MT 840 projector with just over 600 hours on the lamp counter. I live in Japan. After about 4 or five minutes of working, the projector turns itself off and won't...
hi,
Possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. if the RPM of fan is low then the lamp can get over heated. May be its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
i have added a video how to oil the fan for make it easy for you.
ok
May 08, 2011 | NEC MultiSync MT840 Multimedia Projector
NEC VT670 - Lamp won't light. Replaced with new lamp, but gives same error. The manual says to wait a minute and then turn on the power again, but this does not work.
I have the same problem. The lamp appears OK. but she isn't coming on. It seems like a problem to start the lamp.
Did you find a solution?
Jan 22, 2011 | NEC VT670 Multimedia Projector
Power light flashin orange, status light flashing red on WT610 NEC
if the status light is flashing .5 seconds on and 2.5 seconds off - you need to replace the lamp cover correctly.
if the status light is flashing .5 seconds on and .5 seconds off in 2 - 6 cycles the error is: 2 cycles - the projector is overheated. Move the projector to a cooler location, or/and remove dust in the light path. 3 cycles - the power unit is not working correctly. 4 cycles - the fans are not working correctly 5 cycles - lamp fails to light. Wait a full minute and then turn on again.
Jan 25, 2009 | NEC WT610 DLP Projector
Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Apr 01, 2008 | NEC VT47 Multimedia Projector
NEC LT30 - Lamp dosen't turn on.
From the manual: To reset the lamp hold down the "HELP" button on the remote for 10 sec and the lamp indicator will turn off. Then start up the projector again.
It worked for me!
Mar 17, 2008 | NEC LT30 Multimedia Projector
NEC VT47 Lamp type VT70LP will not power up 2 red lights spear Lamp not working
When the lamp exceeds 2100hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 27, 2008 | NEC VT47 Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
