Question about Maytag MBB2256GES Bottom Freezer Refrigerator
Refrigerator is not cool
Freezer works fine
  • Maytag Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorRefrigerator is not cool - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
rayname
  • 70 Answers
SOURCE: Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
I replaced my evaporator fan behind panel in freezer this was not spinning had to remove ice maker and panel to access got parts list emailed from kitchen aid and picked up part at local appliance dealer
Posted on Jan 03, 2009
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
  • 340 Answers
SOURCE: Avanti refrigerator not cooling
thermostat set ? might not be defrosting all the way. damper actuator not opening from freezer to refrigerator. is the condenser clean?
Posted on Jun 17, 2009
  • 9 Answers
SOURCE: my refrigerator is not cooling the freezer is working
please check the rear interior freezer wall to see if there is any ice built up.If yes,that means you have a defrost heater problem.The defrost system consists of 3 components,1)defrost timer,2)the actual heater(which is located right inside the evaporator coil compartment),and 3)a terminating stat(which shuts off the the heater before the heat cycle ends to prevent overheating).There are ways to test this with a volt and amp meter. So,if this is the case,and you need a temporary fix,and I do mean temporary,(3-5 days)you can turn off the fridge for 24 hours and leave just the freezer door open until the ice melts,OR unplug fridge,then remove the interior back panel of the freezer and melt the ice by pouring hot water over the iced up coils(CAUTION:DO NOT POKE IT WITH AN ICE PICK OR ANYTHING,YOU WILL MAKE A HOLE IN THE EVAPORATOR).after ice is melted,reassemble rear panel plug it in,and it will buy you a few days. In a refrigerator, all the cold is produced in the freezer section,then through a small hole in the dividing wall,a small percentage of cool air is blown into the fresh food section.When the coils do not defrost 3-4 times a day like they should,the air cannot pass thru them and no air will be delivered to the fresh food section. Now, if you don't see any traces of ice buildup,you may have the air exchange door in the wrong position.The air door is a little door that determines how much air is passing thru to the fresh food section.Most fridges have the selector with either numbers or letters.Example A-B-C-D-E OR 1-2-3-4-5.Now when this air door selector is in the "1" or "A" position it means the maximum amount of cold air is going to the fresh food section,which in your case,is where you want it to go. Anyway if this is the case with you, after you have made the adjustment,please wait 24 hours to take effect,it's a slow process. I hope these suggestions help you. I know I probably gave more info than you needed to know. Good luck
Posted on Aug 26, 2009
heatman101
  • 43501 Answers
SOURCE: freezer works refrigerator does not
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
heatman101
Fan in freezer area does not turn on, refrigerator no cooling, freezer works fine
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 18, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator not cooling freezer working fine suggestions
heatman101
Dec 15, 2010 | Maytag MBB2254G Bottom Freezer...
Fridge not working (light on - not cold) and freezer working fine.
heatman101
Oct 18, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer working fine refrigerator below not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 11, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer is working fine. The refrigerator is not
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
EL7ATRR Refrigerator: Freezer working fine but fridge not cooling...
heatman101
May 17, 2010 | Whirlpool EL7ATRR Refrigerator
Not cooling but freezer works fine
heatman101
Jan 24, 2009 | Kenmore 50522 / 50524 Side by Side...
Top refrigerator part not cooling, bottom freezer and fan working
heatman101
Nov 26, 2008 | Amana ABB1927DE Bottom Freezer...
Open Questions:
See all Maytag MBB2256GES Bottom Freezer Refrigerator Questions
Maytag MBB2256GES Bottom Freezer Refrigerator Logo
196 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
