Question about Garden
On the Home light chain saw 16 inch 2.3, are both of the tanks for the gas and oil mixure or one for the gas/oil mixture and the othe one for something else..I do not have a manuel ?
    Problem Solver:
  • 5 Answers
One tank is for gas/oil mix, should be at the back of the saw. The other is for bar oil - light weight oil, should be at the front of the motor so that it can automatically squirt the oil on the bar. Please don't take this the wrong way, but if you don't already know this then download the owners manual from the manufacturers website, buy chaps and a face gaurd and don't cut your leg off.
Posted on Aug 02, 2009
What is the oil capacity for the Hornet 14" Mach 2
Usually about 3-4 ounces in the bar oiler tank. The fuel mixture you can find at McCullock.com.
May 03, 2014 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chain gas saw
If you are looking for the gas/oil ratio, McCulloch recommends 50/1 gas/2cycle oil mixture.
Oct 05, 2013 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
Oil,gas mixture for a McCulloch 610 chain saw
Always use good quaility two stroke oil designed for use in chainsaws ( not out board motors ) and mix at 40-1, oil quaility has moved on greatly so it is acceptable to use less oil than was once needed.
Nov 10, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the correct fuel/oil mixture for an older Eager ****** 16 inch chain saw?
It really depends on the model number of your Eager Beav er unit. Anything within the last 6 years is 50 to 1 older models can be anywhere from 25 to 1, to 32 - 1 up to 40 - 1. t all depends on the model number.
The usual fuel mixture is 40 - 1 or 3.2 oz. per gallon.
Your chain saw would have to be pre-1995 to use a mixture greater than 40-1. If your chain saw is other than that then use a 32 - 1 ratio. 4.oz per gal.
This is a great fuel mixture calculator:
http://www.csgnetwork.com/oilfuelcalc.html
If you know your model number you can use this page to get an owners / operators manual:
http://www.mccullochpower.com/node7877.aspx
Jun 16, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the gas to oil mixture for the Husqvarna 340 Chainsaw
The fuel to oil ratio is 50:1. Be sure to use a modern synthetic saw oil available from home centers, hardware stores, and saw dealers. Premix in it's own container with fresh fuel and be sure to shake the container thoroughly just before you fill the tank each time to prevent oil starvation. Hope this helps!
Dec 22, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
In addition to the gas and oil mixture there is a place for just oil....what do I need to put in there ?
That's for the bar&chain oil. It dribbles onto the chain as the saw runs, lubricating the where the chain slides over the slot in the edge of the bar. Without this oil the chain & bar will overheat pretty quickly, ruining both the bar and the chain.
Good luck
Nov 22, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Do not know what mixture or how to use
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
May 30, 2010 | Homelite ZR10926 16 Chain Saw
Fuel mixture for MAC 3200 CHAIN SAW
Mix the oil to gas at a ratio of 50:1.The oil bottle will tell you how much oil and gas you need to get to that mixture.
May 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What kind of oil do I use in the oil reservoir of my chain saw?
I believe the reservoir you are talking about is for the bar chain oil. You can get it most anywhere. As for mixing the gas and oil mixture, you will need 2 cycle oil. It is available most everywhere also. Most modern chain saws use a 50:1 mixing ratio which means 2 1/2 ounces of oil to 1 gallon of gas. Hope this helps.
Apr 26, 2009 | Remington 16" Electric Chain Saw
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
