Question about HP Audio Players & Recorders
My computer says ''no audio device detected'' in the control pannel
My computer speakers stopped working randomly on the 4th Of July. I thought it was the computer speakers, so my uncle bought me new ones. My dad hooked them up and I know they are correct. In the control pannel, it says that there is no audio device detected even though they are plugged in and turned on. Is there a certain program I have to download to make the sound work again? My computer recently had alot of viruses and my dads friend removed them all, so I don't want to download something that will mess up the computer again. PLEASE HELP!
  • ooDaRk07oo May 11, 2010
    What brand is your computer is it a desktop or a laptop
  • 101 Answers
Whats happened is that your "Audio Drivers" have been removed.
Your audio device is inside your PC /laptop, probably on a bit of your computer called the motherboard, but in order for your computer to recognise and talk to your audio device it needs a bit of software called a driver. We need to find out what type of PC / Laptop you have, make another post on here with as much info on you PC/laptop as you can find, and state that you are looking for the audio drivers, myself or one of the other experts will then find the right drivers for you and tell you how to install them
Posted on Aug 02, 2009
My computer doesn't detect my speakers, I do have windows 8
Do you have the AC adapter plugged into a live outlet and have you turned on the speakers? Make sure that the speaker signal cable is plugged into the correct port on your computer (the lime green port on a desktop). Check that the correct audio driver is installed for your computer. (With Windows 8, use the Device Manager to check. From the Start Screen, type in Device Manager. Click on Settings and then select Device Manager. Alternatively, Windows key+C on the desktop. Select Settings and then Control Panel. You can find the Device Manager under System and Security or Hardware and Sound.) Scroll down to the Audio devices. Expand the section and look for a red triangle with an X or a yellow triangle with an exclamation point. Try updating the driver (check with the manufacturer of your computer for the latest driver). Even if you don't see the error triangle, try reinstalling the latest driver.
Next check if the speakers work on another computer. If they don't work, the audio cable may be damaged. Try a different set of computer speakers on your computer.
If other known good speakers do not work and the correct audio drivers have been installed, check the audio output devices. Go to the Control Panel > Hardware and Sound page (as described above). Choose Manage Audio Devices. Check if the HDMI port is set as the default audio device. Disable it for a bit (right click on the device) . Sometimes when a new video card is installed, the audio device defaults to this port. This messes up the drivers for the regular audio.) Reboot the computer and then try reinstalling the audio driver. Reboot again.
If it still fails, there is probably something wrong with the audio device hardware. If you are using an add-on sound card, try disabling it and using the motherboard audio device. (A number of add-on sound cards didn't work well with Win7 or Win8. The on-board audio drivers worked better.) If you are using the motherboard audio on a desktop, try an add-on sound card. (Check for Windows 8 compatibility (drivers) before selecting any card.)
I hope this helps.
May 29, 2013 | Kinyo PA-1158 2.0 Amplified Speaker System
NO AUDIO DEVICE IN CONTROL PANNEL
what type of computer desktop or laptop ?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 09, 2012 | Gigabyte Computers & Internet
No sound is coming out from the speakers an we only owned it for about 3 months.
Please check all the cords associated with the speakers (the one to the computer, the one to the power outlet, ect) and make sure they are all plugged in correctly. Next make sure you have turned the speakers on, I dont know how many times I have thought my speakers were bad and I had turned off the power to them. Next in the lower right corner there may be a speaker looking thing, double click it and make sure you are not muted (can also be found in control pannel (sound and audio devices). Next try in the control pannel, and sound and audio. Make sure the output is set properly. I have seen some computers set to a digital coax out, when plugged in with a standard mini jack. If this is the case change the digital coax to the analog mini jack. Also make sure that it is not selecting only the front port.
Hope one of these helps
Sep 01, 2011 | Cyber Acoustics CA-2014 Computer Speakers
The speakers I have worked just fine, then one day they just stopped working. Now my computer doesn't even detect them. They are plugged in correct and I haven't switched anything.
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 22, 2011 | Polk Audio AMR90 Computer Speakers
My computer keeps saying there is something wrong with my sound card or audio device does that mean that it is something internal. I've tried the troubleshooting and even tried the control pannel settings.
if you cant hear anything coming out of your computer speakers there is something wrong here what to do
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 01, 2010 | HP (400745-001) Sound Card
I deleted some progeammes off my computer to try and make it faster but i think i may have deleted the programme for the speakers and i do not know where i have left my disk when i go to control...
Hello @Rocketships. It sounds like you have removed software / hardware drivers, which translate how the speakers and/or audio should work, to a language the CPU can understand.
Try doing a 'restore' to a date just before you had problems.
Try downloading driver(s) for the device.
Do other sound devices such as head phones still work OK?
If not, you may have to update missing drivers for your OS.
Oct 13, 2017 | Genius SP-i350 Computer Speakers
Audio icon is recognizing speakers but showing not plugged in
  1. Go to control pannel
  2. Go to sound and audio device
  3. Go to audio
  4. nd select ur audio company which is manifacture by motherboard company
Jan 30, 2010 | HP Pavilion m7100y (PX189AV) PC Desktop
2.1 SPEAKERS NO SOUND. CONTROL PANEL DOESN'T RECOGNIZE ANY AUDIO DEVICE & CANNOT ADJUST SPEAKER VOLUME.HAVE NEVER HAD SPEAKERS HOOKED UP BEFORE.
That's your problem. It could be:
* the audio-device integrated on your computer's motherboard is "disabled" -- Windows cannot use it
* there is *NO* audio-device integrated on your computer's motherboard -- Windows cannot use non-existent hardware.
* Windows has not installed the correct device-drivers for the integrated audio-device.
* you have an add-in PCI audio-device, and Windows has not installed the correct device-drivers for this hardware.
Do the speakers work if the output from an iPod is connected to the input-jack on the speakers?
Do the speakers work if connected to some other computer (laptop or desktop) ?
Nov 11, 2009 | Insignia 2.1 Speaker System (3-Piece)
How can i install a new Computer Speakers? I had some speakers on my computer and it stopped working. I thought my speakers were messed up so I got some new ones and now my computer says that there is no...
This sounds more like a sound card issue. Go to Control Panel, System, Device Manager and check your sound card.
The speakers get plugged into the audio output jack on the back of your computer.
Jun 03, 2008 | Audio Players & Recorders
No sound
check in your device manager that you have installed the driver successfully.
1st go to control panel
2nd click on system
3rd click on properties
4th...on device manager and select it and see the status!
Dec 08, 2007 | Logitech V20 Computer Speakers
297 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
