Question about Hayward SAND FILTER, PRO SERIES
I need to change the lateral holder assembly and bottom screen on a Hayward S-200 sand filter. Will I need to remove the variflow valve or will it just come right out?
  • 128 Answers
You will need to remove multiport valve and remove all the sand with a scoop. Not alot of fun. Think about replacing sand with ZeoBrite filter medium when you put it back together
Posted on Aug 23, 2009
Hayward pro series s244 im getting large amounts of sand in pool and the system is drawing lots of air what could be wrong
Either broken lateral drain assembly or the manifold.
If fairly new filter, it could be that you have overfilled the amount of sand, as it is too close to the bottom of the variable position Multiport filter valve.
Hayward SX244DA Lateral Assembly With Pipe
May 24, 2015 | Hayward Industrial Products Hayward Pro...
Lateral assembly cracked at bottom
You will need to replace the laterals with the exact ones you have or they will not thread in.
Hayward filter parts are available at many different online stores.
Rod
US Parts Center
May 12, 2013 | Hayward SAND FILTER, PRO SERIES
Sand Leaking From Filter into Pool. When my filter is running I am experiencing sand in the bottom of my pool from the filter. What can be causing that?
There is only one thing that can cause sand to come back into the pool from a sand filter. The internal assembly, called the lateral assembly, is either cracked or broken. This is an easy fix and should cost you around $70 to replace the whole thing. You need to unscrew the bottom drain cap on the filter to remove the water in the tank. Then, remove the multiport valve on top of the filter. Take a shop vac and remove the sand in the filter. If the sand hasn't been replaced in the last 3-5 years, this would be a great time to do that since you already have the sand out anyway. Then, remove the lateral assembly and inspect the entire thing. After you replace the lateral assembly, you'll need to fill the sand filter tank 1/2 full of water before adding fresh sand. This is done to cushion the laterals from the weight of the sand. Cover the hole in the top of the lateral assembly pipe with a cup or duct tape to prevent any sand from getting inside the pipe (the sand will come out into the pool if it gets into the pipe). Fill the tank 3/4 full of pool filter sand. Make sure it is genuine silica pool filter sand from a pool company. A lot of big box and home improvement stores sell play sand as filter sand. This will cause you more problems!
Jun 16, 2011 | Hayward SAND FILTER, PRO SERIES
Sand coming into pool from newly installed 220 hayward sand filter. It was recommended by the local pool distributor to add a 50 pound bag of gravel to the bottom and then 200 pounds of #20 sand. Should...
The problem was you didn't fill the tank with water or added the gravel to fast and now the lateral assembly is broken and letting sand into the pool. You'll need to empty the tank and replace the laterals. Add gravel slowly after you fill the tank half-way with water first.
John
May 13, 2011 | Hayward SAND FILTER, PRO SERIES
How do i change the sand in the hayward model sp 711
Hello, 1 You need to unscrew the drain plug and screen (if it is still there!) at the base of the filter. 2 You can reclaim most of the sand by letting the filter drain through a sieve (lots of work) or use new sand. 3 Uncouple union joints or couplers that attach to filter head. 4 Remove filter head. 5 You can try pulling some sand out of the top. However, do not damage the filter fingers in the sand. 6 Use a hose to blast the sand out the bottom drain. 7 Inspect all fingers, replace if necessary. 8 After all is cleaned out, place finger mount inside filter. Cover top of mount with a cup or similar to keep the new sand out of the finger assembly. 9 Replace drain plug and screen. 10 Fill filter halfway with water. 11 Slowly pour sand in and spread evenly. 12 Remove mount cover. 13 Reinstall head, unions and couplings. 14 Prime pump and test for leaks.
Good Luck
How to change a lateral in an s244s hayward sand filter
You will have to remove the sand so you might as well buy new sand. Remove drain cap and allow to drain. Remove multi port valve from top of filter. This model should have a clamp holding the valve onto the filter. You will have to disconnect the piping from valve for removal, so if it's piped solid, cut piping, and buy PVC unions to glue back in place so you can open in the future. If it's hose, then no problem. OK so once you remove the valve, you can see inside and see the sand. Take a shop vacuum and vacuum the sand from the filter. Take your time and empty vac, before it gets too heavy. Once empty, you'll see the laterals in the bottom. They if you rinse them off with a hose, to remove sand to keep from binding. The laterals should fold up to the center. Once folded you can remove assembly. After installing new laterals, partially fill the filter with water before adding sand. Cover the down pipe so no sand can enter. Add sand gently so you don't break new laterals (water helps cushion the adding of sand) You can download a manual here :
http://www.haywardnet.com/products/Manuals/pdfs/Manual145.pdf
Jun 25, 2010 | Hayward SAND FILTER, PRO SERIES
No suction from hayward variflow pro series sand filter
Try these tips. I am guessing that one of these is the reason that your pool filter is not working properly. If you try these suggestions and they don't work, let me know and I will trouble shoot with you again.
1. Check skimmer and pump strainer baskets for debris.
2. Check for restrictions in intake and discharge lines.
3. Check for air leak in intake line (indicated by bubbles returning to pool.
4. Backwash your filter.
5. Be sure Vari-Flo valve is set on “Filter” position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
Instructions on placement of the lateral assmebly w/center pegs
That placement is automatic based on the center pipe resting on the bottom of the filter tank and the valve being fully seated into the opening on top of the filter and clamped into possition. You likely have damaged laterals and need to replace that assembly in order to fix the sand issue. When refilling the tank with sand, be sure to fill it nearly half way with water before adding the sand.
Jul 15, 2009 | Plumbing
How to change sand in Hayward S-200 Sand filter
hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
Apr 27, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
277 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
