Question about Coleman Mach III Air Conditioner
No blower after 20 minutes of running but compresser is still working.
  • 3,361 Answers
Check for oil ports on the fan motor. Oil the motor if ports are there. Replace the fan motor capacitor. If same problem persists, replace the fan motor.
Posted on Aug 02, 2009
My craftsman snow thrower runs for about15 minutes before it requires more chock until it finally cannot run. Why is this happening
First i would check engine compression. It will change once it gets hot and cause you to use more choke until finaly it wont run.and if that is okay i would rebuild the carburator. A rule i use in my shop is to always check compression first then go from there.
Dec 13, 2014 | Craftsman Garden
What is the compression on a poulan leaf blower?
60 to 70 psi it will start fine. I fix Poulan blowers every day for a living
they are very easy to fix. A common problem is stuck piston ring.
Jul 10, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
Starts runs a couple of minutes then dies
It sounds like you have a bad Ignition Coil (Module). This is how they act when they start going bad. When they get warm, they quit. Some will last up to 20 minutes before they shut down. You can sometimes find a used one pretty cheap at a small engine shop.
Jim
Aug 07, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Toro gas leaf blower erratic engine performance
hi
change the sparkplug or seals.
bye
Oct 04, 2009 | Garden
Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
Apr 04, 2009 | Echo Garden
Homelite yard blower won't start
1st how old is the gas and 2nd how long did it sit for since you last used it? If there was any old fuel left in before now (more than 14 days) than it is possible your carb needs cleaning. If it's less than 14 days then you might want to check the compression. IF you have good compression, then you might want to take it to a service center to have it diagnosed.
Dec 27, 2008 | Homelite 'Yard Broom' Leaf Blower
Coleman Mach III Air Conditioner Logo
200 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
