Question about Canon PIXMA MP600 all-In-One InkJet Printer
MP600 canon printer computer cannot recognise USB device
My MP600 canon printer worked fine. But recently a problem emerged. The computer cannot recognise USB device, and wont connect. I get the same problem when I attach it to a different computer.
  • 3 more comments
  • pk2007 Nov 28, 2007
    I have the same problem. All of a sudden, for no apparent reason, I got the same error message. I un-installed and reinstalled everything, still no dice. Tried it on another computer, same thing. Help?
  • koosr Dec 07, 2007
    printer worked fine , suddenly comes an error code can´t find the USB
    installed the software again
    tried another cable
    tried another usb port
  • Anonymous Dec 08, 2007
    have the exact same problem but i have tried all different ports and a new cable
  • koosr Dec 08, 2007
    fixed it
    went to the bios and selcted "no boot" for usb controllers
    see also www.canondv.com and go to support and search on "USB"
  • ttt128 Jan 11, 2009
    It was working fine for a few years and all of a sudden the computer will not recognize the printer. The same thing happened when I was using the printer on my old Dell.
Fixed it
i went to www.canondv.com go to support and search on USB
i have a dell computer and i changed inside the bios the USB emulation into "no boot" and it worked again
Posted on Dec 08, 2007
  • 57 Answers
Try different USB ports on the computer to see if its a porblem with the port connection and if there's no change there then try using another USB cable that you know is working perfectly fine.
Posted on Nov 28, 2007
Wh doesmy canon mp600 printer have a message that says device incompatible and there is nothing inserted/
it means your computer does not recognise the printer you need to change the formatter board for your printer
Jun 27, 2014 | Canon PIXMA MP600 all-In-One InkJet...
MP600 MFP was working fine then recently can't be found as a USB device. Tried changing cable and USB port on the (DELL) computer and it makes no difference.
hi;
look at the USB connector located on the printer is it broken ?
light it with a torch look inside the 4 pins are they fine ?
Nov 05, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 printer wont print
check first if printer work fine, you can test print it manually, then check if computer communicate with the printer by allowing to remove driver and insert usb cable it must be popup that found new hardware occurred for its detecting printer. reinstall back driver, restart and send print test.
Mar 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My Canon MP460 has malfunctioned and Windows doesn't recognise it
Check your user manual for instructions on how to reset the printer to factory defaults.
Oct 12, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Pixia MP600 had been working fine but now computer with Vista fails to recognize it and says something on connected to USB has malfunctioned. Also where can I get a installation cd that is in English. The...
while you install the software cd . you can see the language settings for display there you can change your own language. dont connect the devices before you install the software cd while you install the cd it will ask you the default settings from there you can change the setings.
Jun 16, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp600 stopped connecting to computer
try to transfer the usb cable to another USB port..or swap with the another working USB port..and restart your computer..
May 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Difficulty printing
First of all, delete all the copies of that printer in the folder and try again. If possible delete them all and reinstall the printer.
Apr 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printing directly from a memory stick via the MP600 USB port
Your printer may not have the ability to recognize the files you have in the stick. Did you ever think of that?
Jun 20, 2017 | Canon PIXMA MP600 all-In-One InkJet...
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
My cannon pixma 160 wont print
computer won't 'recognize device'. USB cable appears ok. USB ports work with other devices
Nov 05, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
414 people viewed this question
old marine
old marine
