Question about Toshiba Tecra A8 EZ8511 Notebook
Fingerprint security.. Dear Sir, How can I enable or register my fingerprint security in my Toshiba Tecra laptop?
  • 51 Answers
Re: Fingerprint security..
You should see Credential Manager in the lower right corner of the screen (once booted to the desktop). Right click on that and select My Identity.
This will bring up the Credential Manager and you should see link to register fingerprints.
Hope this helps :)
Posted on Nov 26, 2007
0 characters
3 Points
Tecra m5 fingerprint scanner anable
Go to Toshiba website and check under support for specific problem.
Mar 08, 2012 | Toshiba Tecra M5-S433 Notebook
Toshiba tecra A7 fingerprint and password. fingerprint device f*#ked and i dont know password. HELP
I would contact and speak to their technical department as I am sure I have read a bullitin about that issue by way of an updated driver and BIOS firmware update.
Hope that helps.
Jan 16, 2011 | Toshiba Tecra A7-S712 Notebook
I need to reset my bios password.i have forgotten the password.but i have the fingerprint that enrolled.but i have unchecked logging on with laptop is A8-S8314.thank you
To reset the BIOS read the information from this link:
In case of your laptop the easiest method would be using Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 20, 2010 | Toshiba Tecra A8-S8314 Notebook
I don't know how to use the finger recognition on my toshiba satellite , please help
Hello there!
Take note that for security-minded individuals, some Toshiba laptops can feature a fingerprint reader. This is incredibly more secure than facial recognition. You are the only person the world with your fingerprints. As long as you keep all your fingers on your hands, using the fingerprint reader is a secure way to logon to your laptop. A fingerprint reader is accurate and almost impossible to deceive, unlike facial recognition software. The convenience offered by the Toshiba fingerprint reader does not add any security risks. You can simply place a finger on the reader and access your user account.
There is several ways on how to set it up and it depends on the model. May I ask, what is the model of your Toshiba laptop?
Nov 13, 2010 | Toshiba PC Laptops
Can you solve the problem for my lap top Toshiba satellite E105-S1402, I am not able to register my finger print on TrueSuite Access Manager Finger Print. The error message come "failed to open the sensor"
You can try to download and install the Fingerprint Utility here and check if you will receive the same error message.
Refine Search by: Your Operating System (Vista by Default)
All Categories: Security
Title: Toshiba Fingerprint Utility for Windows Vista / XP
Download and Install
If the reinstallation of this software does not help then the issue must be related to a corrupt Windows Vista files and in my opinion the usage of the Toshiba recovery CD should helps.
Thanks for using Fixya
Jul 29, 2010 | Toshiba PC Laptops
dentifying the fingerprint readerA fingerprint reader provides extra security for the PC. The VeriSoft Access Manager by Bioscrypt uses the fingerprint reader to identify the user, and controls access to Windows or other secure systems. Instead of typing a User ID and password, you can move your finger across a sensor to logon or start commonly used applications. Verisoft Access Manager can manage all of your different secure accounts and the required user names and passwords by recognizing your fingerprint.On HP notebook PCs, the fingerprint reader is a small metallic sensor located near the keyboard or display. By swiping your finger perpendicular to the metallic sensor you can logon to the PC, a network, or open a program. c00897920.gifBefore you can use the fingerprint reader, you must set up the fingerprint reader by registering your fingerprint with the Access Manager. Set up the fingerprint reader To set up the fingerprint reader to recognize a user, the user must have a logon account on the PC and the account must have a password. Multiple users can be registered for the fingerprint reader if each has their own user account.
  1. In Windows, double-click the VeriSoft Access Manager icon c00897921.gif in the notification area of the taskbar to open the My Identity window. Alternately, click Start > All programs > Verisoft > My Identity .
  2. Click Log On to open the VeriSoft Logon Wizard. Click Next to begin.
  3. Enter the User's Windows password in the Password field on the Introduce Yourself page, and click Next . If you have successfully logged on to Windows, click Finish to close the wizard.
  4. Click Register Fingerprints on the My Identity window, to open the VeriSoft Logon Wizard. Click Next to begin. c00897922.gif
  5. Select a finger shown on the hand graphic, and then slowly swipe your finger across the sensor. One of the squares below the hand graphic will change color when the scan is accepted. A message displays if the scan is not accepted.
  6. Swipe the same finger across the sensor again until all four squares change color, then clickNext to register the finger print. If you need to start over during the fingerprint registration process, right-click the highlighted finger on the screen and then click Start Over .
  7. If prompted to register a second fingerprint, click a different finger on the hand graphic, and then repeat steps 5 and 6.
  8. After using the Registration Wizard to registered at least 2 fingers, click Finish .
  9. To set up the fingerprint reader for a different Windows user, log on to Windows as that user and then repeat steps 1 through 8.
After registering your fingerprint you can log off and then use your registered fingers to log on to Windows. Using Fingerprint reader before registeringIf you swipe your finger across the fingerprint reader before it is set up, the Access Manager opens a logon wizard window and prompts you for informa
Feb 03, 2010 | HP Pavilion DV5234US Notebook Laptop
I disabled my fingerprint sensor, how can i activate it again? appreciate your support
Dear sir,
If you are diabled fingerprint sensor in BIOS,go to the bios enable finger print sensor.
If you are disabled fingerprint sensor in windows.
Enable it in device manager of control panel.
Aug 08, 2009 | Acer Aspire 5720-6661 Notebook PC
Toshiba Tecra A8 EZ8511 Notebook Logo
172 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
