TCL 40FS4610R 40-Inch 1080p 120Hz Smart LED TV Roku TV Logo
Posted on Aug 06, 2018
I have a TCL TV and the screen went black. I am pretty sure it's the main board and 2 voltage regulators on the board. How do I read the numbers on top of a TV main board voltage regulators.
I have 2 regulators on the main board one is AS1117 072w 33cx ad the other is AS1117 012f adx. I am pretty sure one or both are not working as one reads 5.09, 1.84, 0.58 output 1.84, the othe reads 5.09, 3.34, 0.00 output 3.34
5 Related Answers
A
Anonymous
  • Posted on Apr 20, 2007
SOURCE: DMR E55 won't read RAM Discs
clean the laser lens do no use a lens cleaner disc you need to dismantle the drive unit and clean lens with cotton bud and a isoproplyn solution also clean the disc turnble and clamp if possible get it done by somebody who knows what they are doing
A
Anonymous
  • Posted on Aug 30, 2008
SOURCE: black screen on vizio
it may be the inverter part.
Anonymous
  • Posted on Oct 06, 2008
SOURCE: help for TCL Brand of tv
I WANT THE SERVICE MODE CODE FOR MODEL NO: DP21E101 TCL TV 21"
Anonymous
  • 502 Answers
  • Posted on May 27, 2009
SOURCE: I changed my macbook screen,
This could be a backlight issue, an inverter issue or a logic board issue. Look at the screen closely, if there is a faint image it's either a backlight issue or inverter issue. To weed out between the two you can just order on inverter, they're 20 bucks on ebay, if that doesn't work, replace the backlight. Maybe the new screen was not wrapped right when it was shipped, that can easily break the backlight bulb. make sure you connected the inverter to the white and pink wires correctly. Backlight repairs are somewhat difficult. As much as I would like to be able to tell you a quickfix that will solve backlight the problem, it's a pretty arduous repair that requires 1-2 hours for a trained person. It's feasible to do it yourself if you're tech savy, but you'll most likely have to google for guides that show you exactly how to replace the backlight step by step. I work for Mac Repair NYC and i have to fix this problem a lot, it's so easy to break the lightbulb in the process.
Anonymous
  • 2178 Answers
  • Posted on Oct 24, 2010
SOURCE: I have a Polaroid 42" TLX-04244B. When turning the
The Inverter is trying to produce the high voltage to light the backlight. It looks like it cannot hold the charge to maintain the high voltage level in order for it to stay on - you get a momentary display at initial power-up thus see the logo. Replace the Inverter board.
I have changed main board & power board on TCL 55405STKAA, however the picture comes up for a min or so then goes to black screen
Did you do the necessary testing before changing the boards or are you just throwing boards at the TV hoping for the best? For starters, are you loosing backlights, what is your power supply enable voltage when the set goes black, does it hold at about 3 volts or drop? Do you have PMW signal when the set goes black? How about the hot side of the backlight supply does it stay over 100 volt or drop off? These are all questions you need to find out to fix the set, if you don't know what I'm talking about either take the set to a repair center or buy a new TV. Going by the history of TCL sets I'd wager you have defective LED backlight strips but those are somewhat hard to change and fairly costly, you need to be sure they're bad before changing them. Adm Andrew has a post on fixing your own TV that's spot on.
75 tcl black screen, is this backlights or main board?
Its either the backlight or the power supply to the backlight.
1helpful
1helpful
2answers
My TCL TV is black screen
That is usually a sign that the power supply or the LED's in the display are failing. You may be able to order new power supply or parts for it from shopjimmy.com
Samsung TV, UN60EH6003FXZA, Black screen, has audio. Replaced t-con board and TV worked fine for 5 minutes, then black wave came across screen. Can replace main board, is the new t-con board ruined?
If the new T'Con too have damaged, surely its main power supply regulator board is faulty. Over voltage to T'Con board. Replace it and the T'Con board. Never switch on the set, without proper fittings to T'Con board. Its protective cover should be fitted before you switch On the set. It acts as a shield as well as a heat-sink to the IC at the T'Con. If you switch On without properly fitted, the IC will overheat within minutes and will be damaged. Keep this in mind next time.
https://electronicshelponline.blogspot.com/
1helpful
TV repair?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
1helpful
2answers
50" proscan led tv new main board but still same issue....
Check whether the control voltage comes to the inverter section cirlcuit at its power board; from the main board. There is a control voltage that controls the light intensity; as well as start, of the inverter section circuit at the main power regulator [SMPS]. It should come from the main board. It this voltage is absent, the main board is faulty. Check whether it is present or not. It will be best to contact any service technician in this case. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
How i repair my tv model le40fhde3000 TCL do not turn on?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sony Trinitron KV-2726R Goes out after a while
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
john h
ADMIN Andrew
ADMIN Andrew
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
