Question about Acer Computers & Internet
When a turn on My Aspire One the LCD screen is black and doesn't respond. Please help me and show mw the problem.
  • 98 Answers
Sometimes its as simple as taking your battery our of your laptop, wait a minute then put the battery back in.
Posted on Aug 02, 2009
Panasonic VIERA TC-L42U5 42-Inch 1080p 60Hz Full HD LCD TV (Screen doesn't work)
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 01, 2017 | Panasonic Televison & Video
Acer Aspire 4930 not starting.... only black screen
Hook a spare monitor to the video output, usually on the back, if picture okay! the LCD screen on the laptop has a bad inverter board or the backlight behind the screen has failed. But if both show the same symptom the Video Graphics Card is bad usually built into the motherboard.
Mar 21, 2012 | Acer Aspire 4930-6862 Laptop
My acer aspire 5532 comes on but screen is sill black.. How do I fix it?
Hi skinner fran...
You may have a faulty LCD or LCD inverter.
There is a way to check and see if the LCD is faulty.
Turn off your Aspire, then you will plug your Aspire into a different monitor and if the picture comes on then it is your LCD faulty.
If it stays black, then it is your LCD inverter that is faulty and needs replacement.
Please take time to rate me
Aug 24, 2011 | Acer Computers & Internet
I have an Acer Aspire 5515 laptop. My computer will turn on but it shows a black screen. I've tried turning it off and back on again. Removing the battery but it hasn't helped. Any suggestions??
Wow this is tuff,
Setting from keyboard, possibly.
Software, not likely.
Video Card, possibly.
LCD Screen, very likey.
But with no screen you options at home are limited.
There is a setting on laptops that allow you to send the video output to an overhead projector and cuts the laptop screen off. However, when you re-boot it usually defaults to the screen.
I betting on a screen failure. You may want to take it to a PC Repair shop. Or, buy one here,
http://www.hootoo.com/154-inchs-acer-aspire-5515-laptop-lcd-screen-panel-p-11162.html
http://www.amazon.com/ASPIRE-LAPTOP-SCREEN-SUBSTITUTE-REPLACEMENT/dp/B003XHDARC
Good Luck
Aug 12, 2011 | Acer Aspire 5500 5570-2609 Laptop
My acer aspire bl51 doesnt open up at all, the power turns on , but there is a black screen what can I do to remedy this?
Hi liquidblue7,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 12, 2011 | Acer Aspire 5100-5022 Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Acer Aspire 5920 laptop is showing blank scren w/blinking cursor
yea yur harddriv crashed... try formattin yur drive and create a new partion and load OS .. if it still doesn work then yu ll have to replac yur drive..
May 01, 2009 | Acer Computers & Internet
Black screen but mouse coursor still showing and movable
Hi has your laptop started working again?? removing the battery for 10 min thin puting it back in and restarting will work sometimes
Apr 10, 2009 | Acer Aspire One A110-1831 Notebook
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Computers & Internet Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
