Question about Cavs JB199-250GB Karaoke jukebox & Digital Recording. Build-in 250GB hard Drive.
Broke left side tray on cavs jb-199. where can I get parts?
  • 10,865 Answers
You can get the parts directly from cavs. here is the info you need to place the order
CAVS Service Department
Tel: 1-562-777-0491
Fax: 1-562-777-1851
Email: service@cavsusa.net
10707 Fulton Wells Ave
Santa Fe Springs, CA 90670
Office Hours:
Mon thru Fri 8am to 5pm PST
Tel: 1-562-777-0491
Fax: 1-562-777-1851
Office Hours:
Tel: 1-562-777-0491
Fax: 1-562-777-1851
Office Hours:
Tel: 1-562-777-0491
Fax: 1-562-777-1851
Office Hours:
http://www.cavsusa.com/service.htm
Posted on Aug 02, 2009
  • Gene
    Gene Aug 06, 2014
    Need help with CAVS JB199 I recommend calling Bob at CAVS EAST. He's very fast and a whole lot better than talking to the ones at the company that you can't understand what there saying. Tel # is 301-876-4535 Tell him Gene sent you
  • Gene
    Gene Aug 06, 2014
    Believe me you won't be sorry calling him. Especially if you live on the east coast. It takes CAVS weeks to get you machine fixed. Not so with this guy!!!! Remember tell hell gene sent you.
I have a CAVS JB99 and would like to add a hard drive (EXTERNAL) to it. I need a hard drive that connects to an IDE ribbon cable. Where can I find one?
external hard drives do not connect to IDE cables. you may want to check this information again and make sure that you are not needing scsi
Jun 29, 2011 | Cavs JB-99 3-Disc CD Changer
GSS201ETA BB Right Side is not cooling ( Freezer on left is fine, have removed all shelving and ice tray ) No cold air is flowing to the right side ! What do you suggest to troubleshoot ? Thanks in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | GE GSS20IEP Side by Side Refrigerator
Jb199 doesnt display welcome page,I push the power knobe but it doesnt response the thing is that cavs shows me thepower is on and thats all   next step is wellcoming  but it doesnt go further     ...
Pull cover off box and remove battery (small toward the front of the machine) This will reset the Bios.. after that when restarting go into the bios by pressing the "Delete" Key and hit load failsafe bios. this should fix everything.
Jun 01, 2009 | Cavs JB199-160GB Karaoke jukebox & Digital...
Won't make ice
I've tried a home made fix to this problem which is working so far. It's a bit of work, so proceed with caution. The problem at least with mine was the back of the gear/motor assembly box. There is a back side of a gear that projects out of the gear box and into a slot in the ice tray. It seems to be made of cheap plastic that broke from all the twisting of the tray. Mine left a couple of prongs still on the gear from the break, which I was able to JB Weld and shape back into a tight fit with the ice tray slot.
To start, push the black button that projects down, holding the gear box in place while at the same time pulling the gear box towards you. The ice tray will fall at this point.
Now the gear box is just hanging by the power cables. The only way that I found to get the box out was to take out the four screws in the corners of the gear box, (careful, there are loose gears in there that can come out) and pull the motor, and circuit board out by their cables. If you did this without any gears falling out, put the clear plastic cover back on so that they stay in place.
If the gears fell out, like mine did, it's not to difficult to figure out how they go back in.
Now if you have enough of the gear protruding out the back to add the JB Weld to, than do that and shape it to fit the slot of the ice tray. I had to let it dry, then sand it to the right fit. Hope this holds for a while. I couldn't order just the gear, and the motor/gear box is $70.
Once shaped, make sure that the gear is rotated in position to let the "Ice tray full" arm drop down. Then take of the clear cover, put the circuit board and motor back into place, then put the cover back on. Put the rear of the ice tray into the hole in the back of the freezer, the put the motor box back into place the way you removed it sliding the new prong into the ice tray slot and cross your fingers.
Sep 08, 2008 | Samsung RS2578BB Side by Side Refrigerator
Lexmark Optra T612
The broken part is called the bell crank arm part number 56P1228 this is very common. If the printer isn't recognising your tray, remove it and check the little plastic fingers on the left side (half way down the tray) and the metal springs in the printer (left side) which the tray pushes on to.
Aug 04, 2008 | Lexmark Optra T612n Laser Printer
CAVS DVD 105G having trouble reading super CD-G disc
just got the CAVS 105G and the tray will not open.  Could there be a shipping brace that needs to be unfastened in order to open the tray?
Jul 09, 2008 | Cavs DVD-105G
Jb 199
Oct 18, 2007 | Cavs Audio Players & Recorders
Cavs JB199-250GB Karaoke jukebox & Digital Recording. Build-in 250GB hard Drive. Logo
Top Cavs Audio Players & Recorders Experts
janman
da surgen
Gene
Gene
Level 1 Expert
Are you a Cavs Audio Player and Recorder Expert? Answer questions, earn points and help others
