Question about Peg Perego John Deere Farm Tractor and Trailer
JD push mower doesn't have enough power to throw
JD 14 PZ push mower doesn't have enough power to throw the grass. New air filter and spark plug new this spring. Tipped it forward and some oil leaked Also pulley bracket on a JD mower deck is bent. Can I just straighten it or replace it?
  • Anonymous Mar 26, 2014
    model lx277 tractor
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Wrong forum
Posted on May 22, 2012
  • 77 Answers
I would have a compression check done on the push mower,if it has bad compression the engine needs rebuilt or replaced. As far as the bent bracket,if you can straiten it thats what I would do,mabey get a torch an heat it first.
Posted on Aug 09, 2009
Lawnboy mower model 10743 will not start
When choke not on all the way coil willnot activate and throw spark ps carby should be cleaned out properly because fuel will off evaporated leaving oil guming up needle/seat
Jul 03, 2016 | Garden
Why does my zero turn mower struggle when trying to cut grass, it seems to be using half power.
If is a twin cylinder engine this could be very well the problem. Without the engine info it is hard what it could be.
Jul 23, 2014 | Craftsman 42 in. Precision Cut Plus 24hp...
Toro 24038 blade speed governor not working
Not enough torque. Only use 1/2 width of deck on tall grass, go real slow, Ensure side discharge is open! Ensure blade is sharp. Replace spark plug once a year and clean replace air filter. check oil level 30woil.
Aug 10, 2012 | Toro Power Lawn Mower
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Feb 17, 2012 | Garden
Craftsman LT1000 riding mower with 18hp B&S engine. Mower acts like the battery is almost dead. Will try to turn over but doesn't seem to have the power to cycle the engine. New battery, starter,...
There is a compression release device on the cam shaft to allow the engine to spin easier when starting. This is likely the culprit because the starter isn't strong enough to push the engine past full compression. The fix is to replace the cam shaft.
Oct 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray push mower 22" Model 223311X8A Briggs & Stratton motor idles slowly, coughs & spits, stops in middle of lawn and won't restart. Had tuned up, then brought back for recheck. Still...
There are several additives on the market for gasoline, but only a few of them actually help anything. If the additive is relatively cheap to buy, don't expect much results. Gas that hasn't been treated with fuel stabilizer that is a month or more old loses its volatility and can cause issues with engine performance, small and large.
All you guys on the block need to make sure you're using fresh gas, Clean SAE 30 Weight Oil for the Briggs Engines and good clean air filters. Also you can tell when gas is going stale..it starts smelling kind of like turpentine....a smell you'll never forget.
Jul 11, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
My MTD lawnmower is always shut off when the grass is a little bit longer. It's as of not enough power. What's wrong with it?
It may need a good tune up. New plug, air filter may need to be replaced. Also there may be water in the gas. drain gas add fresh gas. Also the carbs mixture may be off. Too much air or too much fuel. hope you get it going.
Apr 23, 2010 | Mtd 22" Yard Machine Push Mower
Clutch adjustment on a John Deere JX 85 push mower
my jx85 when cutting grass with my jx85 the power to the blade dies if i lift it up the power will come back put it back into grass it dies again any ideas please
Jun 21, 2009 | Garden
Peg Perego John Deere Farm Tractor and Trailer Logo
139 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
