Question about Amana Refrigerators
Have an Amana bottom freezer model ABB1924DEB and getting ice buildup on rail under ice maker. Anything I can do to fix? Reduce amount of water going into ice tray?
SOURCE:
aborcass
  • 2651 Answers
SOURCE: Water freezing on the tray section under the freezer drawer.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
  • 109 Answers
SOURCE: Ice maker overflows with water
yes, in fact the icemaker does meter the amount of water delivered to the icemaker, the valve should only be energized for 7 seconds. after that the power is cut off, so if valve continues to let water flow, it's bad (might have debris from water line keeping it open. unserviceable. )
Posted on Mar 31, 2008
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
  • 4 Answers
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
projdoc
  • 2237 Answers
SOURCE: 2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Posted on Aug 28, 2009
We are in Australia and have had an Amana XRSS287BW fridge freezer with ice maker for 5 years. The freezer is icing up near the ice maker, the condensor is not icing up. It appears to ice up and the fan...
they do not repair icemakers for the simple fact it is cheaper to just buy a new unit aka icemaker in fact the icemaker when the repairman buys it costs him between 47-90 dollars at which for him to disconnect the three bolts and reinstall the icemaker the charge usually starting around 189.00 first thing to do would be to look at the tube where the water is going into the icemaker and observe if you have a leak from the tube the next step would be to inspect the icemaker for cracks in the ice making tray if this is also ok has your repairman checked the t-stat this is a small two wire round disc like object located behind the back panel this is what regulates your temptreture and turns the heater on when your freezer gets to cold another thing to check would the drain tube that goes from the bottom tray under the condensor sometimes this also gets blocked with ice.In turn when it does get blocked the ice just builds up the t-stat is located as part number 3 on this diagram from this link http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-XRSS287BW0/1268/0165000/M0610184/00014?blt=06&prst=&shdMod= lastly if your fan is not spinning at the addequate speed that it is supposed to be spinning at then the amount of cold air would not be leaving your freezer to go into your fridgerator and when the heater kicked on the water that melted off the condensor coils would build up also as ice if your repairman is saying its the icemaker visually inspect the icemaker yourself here is a link also showing how to remove your icemaker http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-XRSS287BW0/1268/0165000/M0610184/00008?blt=06&prst=&shdMod= please message me back with your finds after you have visually inspected for yourself. i hope this opinion has helped in your appliance situation please remember to rank how this opinion has helped in your appliance situation and i await your reply
Thanks
Rick
Nov 09, 2010 | Amana Refrigerators
Ice maker leaking into ice storage tray
start with hose replcement buy parts at sears water hose to main ice maker might have crack in it or the stopper is bad get in ther look close with brite light
Oct 14, 2008 | Refrigerators
Ice Maker Problem
You need to check the fill tube it could be ajar. It should be going into funnel at the back, of icemaker.
If so, the valve is bad, letting the water in when its not calling for it.
Jul 12, 2010 | Amana ABB1927DE Bottom Freezer...
Ice maker stopped working, makes tapping sound--like a woodpecker. How do I fix this?
Sounds like your ice maker has a bad heater or thermostat. While these are fixable, it is not recommended. Your best bet is to get new ice maker and replace the whole unit.
Dec 08, 2009 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Water on the ice maker doesn't shut off - drips into the ice pan
Most models of Ice makers have an automatic timer for the amount of water that is allowed to enter the Ice Maker tray. If your timer valve is going bad you need to replace it. First I would reduce the amount of water coming from its source. There should be a tapped valve under your sink, connected to your water line. You have to turn the top of the valve clock wise to reduce the amount of water the is going to the back of your refrigerator. That is where you will find the timer valve. Reducing your water flow should help reduce the volume of water being let into your Ice Maker.
Jul 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker freeze ice together
If mechanical or electronic then it has to be replaced with a modified one no way to adjust.
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
No water comes automatically to the ice maker
What you need is a new ice maker the front gear is not engaging the contacts, you can buy the front module only ( what u put the wire in to on the l & v contact ) but a whole new ice maker assy is the same price.
Jan 10, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Apr 12, 2008 | Refrigerators
Refrigerators Logo
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Carmen Mikulic
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
