Question about Kenmore Washing Machines
My model 22722101 does not aggitate. it does drain. it looks like a gear drive. is it worth replacing?
  • Kenmore Master
  • 3,361 Answers
Replace the direct drive coupling on the motor between the motor and transmission.
Yes, it is worth repairing.
Posted on Aug 02, 2009
Why agitator not trning in kenmore washing machine?
If the spin cycle works, but the unit only fails to aggitate......the problem is most likely a clutch or transmission problem. If the unit neither spins or aggitates, you could have a broken belt or even a defective lid switch. Sometimes a model will have broken dogs, or cogs in the aggitator base. To check this, with the machine off..reach into the machine tub..grab the aggitaror and try to turn it manually by hand. If you can turn it and also feel a sensation such as a gear slipping or teeth not properly taking hold or meshing, the cogs or dogs may need to be replaced that are under the aggitator itself. Best Wishes
Sep 01, 2014 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
When my Maytag Neptune TL washer spins, it make a very loud noise. The repairman came over and said there was a problem with the aggitators or the gear drive for three saucers which will be very expensive...
It sounds to me as though the tub bearing is bad. Very expensive repair ! If it's several years old, I would just replace the washer. Also, if you buy a new washer, take out the extended warranty they offer. I've seen it pay off many times. Hope this helps.
Sep 29, 2017 | Washing Machines
My Kenmore model 80 washer won't aggitate but spins and drains without issue. The aggitator tries to move but acts like there is a gear stripped or something.
you will need to purchase an agitator replacement kit for your washer and, the clutch will need to be replaced as well. these components are damaged and, replacing them will restore your units agitation functions.
Jun 07, 2009 | Kenmore 15944 Top Load Washer
Kenmore 20842 won't spin or aggitate
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
The aggitator (sp?) isn't turning...the rest seems to be working (spin & fill). How do I fix it and is it worth fixing? Model LBT6133A Whirlpool Washer
Go under the aggitator inside the tub and pull out the aggitator it self and check out see if the teeth are strip,If the teeth are strip on the aggitator replace it. If is on the other side then it's not worth repairing. All you need to do is just pull on the aggitor from the bottom.
Apr 26, 2008 | Washing Machines
Agitator will not work on wash cycle
Order the upper aggitator clutch/dog kit $15. Now top half of the aggitator is doing its thing just like the bottom half. Hope this helps someone else too.
Oct 05, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
71 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
