Sanyo clt 2054 dead.just a clicking sound, no picture no sound no power light. replaced main board same problem.
  • 1 more comment
  • wkinn52148 Aug 02, 2009
    The power supply is on the main board which i replaced. Like i said the tv has a clicking sound.
    The power cord is new, the tv makes a clicking sound so it is getting power. Could the inverter board be bad?
    I will let you know.
  • 25 Answers
The Sanyo CLT2054 TV has different version. lcdpayless has all these power supply.
you can checkout as below link:
http://lcdpayless.com/search.php?searchText=clt2054&submitButton=Search
Posted on Oct 09, 2009
  • 10,515 Answers
As there is no Power, there seems an issue with Power Supply. Might be a blown capacitor.
Do you hear any sound when you Plug on the LCD and the Button?
What i assume, it has to be the Faulty Power Supply Board. As you are not getting any power , you should have check the power supply board followed by main board .
Check the Power supply board and invertor circuit and replace it, if Faulty.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 02, 2009
  • 1 more comment
  • taran_2005
    taran_2005 Aug 02, 2009
    Thanks for your response!!
    If you are sure, you have replaced these parts, the only other problem that i can think would be the power cord.
    The Power cords in this model is a light one and many people have faced the issues. Take a voltmeter and check the power supply to the cord.OK you need a volt meter to check the voltage output of your power pack
    as two things cause this now enough power out the pack to run your unit
    or the unit has a short both problems will unlight the light so you
    need to know if the power supply is working right first as it should
    say like 120 volts AC in and 12 volts DC 1000 ma out so you will need
    to mesure this with a volt meter. this is a common problem loading the
    load of the curcuit as in your TV is mor the the power pack is giving
    out thus shorting out the power pack of any voltage present, as the
    little LED light your seeing only takes 5 volts at very ittle current
    to light and dose not repersent the total voltage output of the power
    pack itself.
    If problem still persists, Give them a service call.
    Hope i helped you.
  • taran_2005
    It might be one of the reasons. That's why i mentioned above inverter circuit. Check and i guess, as you have already replaced all the main parts, that's may be the reason.
    Hope i helped you.
  • taran_2005
    Sure!!
    Waiting for the update.
    Thanks!!
What part is needed to restore picture for Sanyo TV model #DP26648. Has sound, no picture
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Nov 08, 2016 | Sanyo Televison & Video
Tv mount for SANYO 2054
Read ur manual,go to ur tv website or go to Ebay.com or Amazon.com to buy ur model tv mount.
Sep 26, 2009 | Televison & Video
Will not turn on after bad storm
It's possible that your television set took a "Hit" from the storm and subsequently got "Fried". There's not much you can do for it now except replace it. For future reference, try plugging it into a surge protector first and then plug the SP into your outlet. The small "circuit breaker" should pop first, saving your appliances that are plugged into it.
Aug 17, 2009 | Sanyo Televison & Video
Converting from analog to digital
if you have cable it is digital, if not buy a converter box
Mar 28, 2009 | Sanyo Vizon LCD-15A2 Television
Have a Sanyo CLT2054 Have flickering picture looks like a strobe; sound is fine
Sanyo CLT 2054 flickering problem is a power supply issue. You don't need to replace it if you can desolder, and solder. Break the case apart that is connected to the ac power cord. Remove the aluminum cover from the DC out end of the PCB. Unsolder, and replace capacitors C9 & C12 (1000mf 16v). Super glue the case back together, and watch TV. Good Luck...............Don't use cheap capacitors use caps that have a low ESR.
Feb 25, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
I have a sanyo vizon flatscreen that the power cord was lost
I need a power cord for a sanyo flat screen t.v. model # CLT 2054. My email as follows is kellykingonly@yahoo.com . Please let me know if you can be assistance in anyway. Thank you.
Jan 08, 2009 | Televison & Video
Sanyo DP42746 42 in. plasma TV
Well I have the same problem with green light and no sound and no pix. After i opened it all up i checked the main power supply board and found all fuses good and the 12vdc side of the board dead. My best guess is this power board has many problems. All the driver boards for the screen are located on the perimiter of the screen. If you loose part of the power supply board you will loose part of functions of the tv. At this time i am looking to replace the entire power board. Will let you know the location and fix soon as i find it. jim jamesgibson@nycap.rr.com
Jun 19, 2008 | Sanyo DP42746 42 in. Plasma Television
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
