Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Compressor runs for short time, then shuts off with fan running
The compressor turns on for a short time blowing cold air just fine, then shuts of and fan just blows warm air out the front for 7-8 minutes before the cycle repeats. Thermostat set on 64 degrees, ambient room temp 85 degrees. The unit is 4 days old and has worked fine up until today.
  • 10,515 Answers
No doubt it's a 4 days old unit, still it's an electronic item and the defect might be a manufacturing one.
There might be many reasons, Few of them would be :-
1. Settings - Few of these have settings that would allow them to either Turn off after some time or at certain temperature. Check the manual offered with it. Try to plug off. Wait for few minutes and again plug in.
2. It might be the faulty fan, which forced the compressor to shut off.
3. More likely, it's either defective Thermostat or Compressor.
If under warranty, Give them a call and replace it.
If not, unfortunately, you might need to spend many bucks to repair, if it being a faulty thermostat or compressor.
Remember as i said - It might be a manufacturing defect.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 02, 2009
  • taran_2005
    taran_2005 Aug 03, 2009
    Also, check the Voltage across the switch. It should be 220 v.
    Thanks.
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
The a/c on my 2010 Mercury Milan quits blowing after about 2 hours of driving. Any ideas?
Sounds to me like the A/C clutch is no good and out of adjustment.You should goto your nerrest junkyard and get a used assembly take the clutch off then you learn how it comes off and install it on yours the save the pump for later use if needed. The clutch should only have a .010 air gap after install between th inner elctro magnet and the clutch plate it's self.
Aug 04, 2012 | 2010 Mercury Milan
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
The capacitor was bad and was replaced. now the system will work fine for about 30 min then the fan the outside unit will stop working. it sounds like the compressor is still on and cold air is will...
Yes, if you changed the three post capacitor that runs the fan and compressor, and the fan is still getting hot and shutting down until it cools off, you may have bushings out of the motor or an internal short. Sounds like you have a job ahead of you of changing your condenser motor. If you do this yourself just contact me I will step you through it . Mark
Jul 10, 2011 | Goodman CLJ36AR42 Air Conditioner
Fedders wall air conditioner
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Jun 19, 2009 | Fedders AEY12F7F Wall/Window Air...
COMPRESSER IS VERY HOT, FAN OUTSIDE BLOWING COLD AIR OUT NOT HOT
Most likely the unit is low on refrigerant. You could also have a restriction in the system. You need to put gauges on the unit.
Jun 14, 2009 | Ruud UBHC Air Conditioner
Dometic AC that the fan shuts off but the compressor keeps running
call dometic dealer. I hear they have a bad circuit board that is replaced.
Jun 02, 2009 | Dometic Rooftop RV Air Conditioner
Running fine but blowing warm air
"it seems to work fine but will not get cold"
Not sure how it can work fine and is not cold. When you say work fine, is the light on and the freezer fan blowing but is the compressor running?
Unplug the Ref and wait about 30 min or so, plug it back in and listen for the compressor to start running. You should be behind the Ref to hear this. If you don't hear it start running then you may hear a clicking noise. This clicking is a problen with the compressor start relay. If the compressor runs but still is not cold then it could be low on coolant.
Dec 16, 2008 | Refrigerators
Heating & Cooling Logo
131 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
