Question about Philips Televison & Video
Philips 42PF7220A/37B won't turn on at all. No green or red lights come on. This happened after we had a storm and the electric just went out. Any ideas?
    President:
  • 1,077 Answers
Most likely it's a power supply board related issue. It maybe something simple like a blown fuse on the board. The fuse replaceable. Radio Shack or Electronic supply place will carry replacement fuses.
The other possibility is the power supply board itself is damaged. It maybe a bad capacitor or a transformer on the board. Replacement boards can be found on the internet. A good place the start is Shopjimmy.com.
Posted on Aug 03, 2009
I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
I have a Philips model Problem with the Philips 50PL9126D/37B 50 in. HDTV DLP TV I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
Apr 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
50PL9126D/37B 50 in. HDTV DLP TV: the red green and blue colors dont align properly...
Your convergence is out. If it's just out a little, you can adjust with your remote or with older sets there are knobs. If it's way out then your convergence block went out and you'll need to replace it yourself if you're technically adept or take it into the shop for repair.
May 17, 2010 | Philips 50PL9126D/37B 50" DLP TV
Plug in green light comes on after a few second red light
replace power supply module part number,LJ44-00101C
shopjimmy.com has it in stock
Sep 29, 2009 | Philips 42PF7220A 42 in. Plasma Television
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
Jul 18, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a phillips 42pf7220a/37 and 7 blink led
The Ymain Board is out if you have the back of the tv exposed disconnect the ymain board and then plug in the tv set and turn it on. the light should remain green and no longer flash. If this happens the Y main and upper and lower buffer boards should be replaced
Jun 15, 2009 | Philips Televison & Video
Insignia 32" TV turns off after turning on and red light comes on
Hi
I have Philips 42pf9431d/37b and i re hucked up my tv.
It truns on and goes to green and red how can i solve it.
Apr 12, 2009 | Insignia IS-LCDTV32 32 in. Television
32 Philips hd flat screen #32pf7320a/37b on for a time,then black
check the capacitors in the power supply that is the first thing to do, just check if anyone is swallen or pregnant jajajaja that's how some people call it
Dec 15, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Philips 42PF7220A/37 42" Plasma TV
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Feb 09, 2008 | Philips 42PF7220A 42 in. Plasma Television
I had a Similar problem where I would turn the tv on and the green light would come on and then the red would follow and blink 7 times. I tried unplugging it and then then replugging it back and it would still do the same. What I did last night was that I unplugged it and then replugged it back, when I saw the green light, I would unplug it again, till the light went out and replugged it, I did that 3 times in a row, and waiting and it came back on. Hope that works. I still don't know what caused the problem to begin with..
Oct 27, 2007 | Philips 42PF7220A 42 in. Plasma Television
Televison & Video Logo
351 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
