Question about Dual XDVD8181 Car Video Player
Aux input video says no signal with a a/v cord from i-pod
Can't switch to the auxiliary
try useing it.. plug your aux cord into whatever your using (mp3 player) as maybe your radio won't switch to aux until it senses that there is audio being played through the input aux cord?
Mar 20, 2013 | Car Audio & Video
Hook up an iPod to Beosound2000 system??
There is an Aux input on the B & O. you can connect the I-pod to through this input. You will need a 3.5mm phono to 2 RCA cable connector. The phono jack goes to the I-pods headphone socket and the RCA ( Red & White ) jacks goes to the B & O Aux input.bobhifi_28.jpg
Apr 01, 2011 | Audio Players & Recorders
I just bought a I Pod dock ASD 11R and would like
Get a 3.5 plug with two RCA plugs and connect it to an aux imput via the headphone out of the dock.
Jan 24, 2010 | Denon AVR-3803 Receiver
I cant play ipod video thru pioneer avh p 3100
Select the Source menu, press the OFF key, touch the screen and select AV MENU, and select initial, then touch AV input 1 until it says I-Pod.
Nov 05, 2009 | Pioneer Car Audio & Video
I have a pioneer AVH-P4100DVD receiver and I have an i-pod touch. I connected it to the head unit w/ the CD-IU200V cord and I can here music but I can't watch my movies off of it.
Shut the radio off. Touch top right of screen. Once done, hit AV Menue. Initial Setup. AUX1. Switch to Ipod. Once done should work. If not make sure the 3mm jack is plugged into the aux input into the back.
Oct 17, 2009 | Pioneer AVH-P4100DVD Car DVD Player
I-Pod hook up
I think the red/white RCA plugs on the back of the CDE-7858 are outputs for the sub-woofer -- they won't work for aux inputs like iPod.  According to Alpine dealers, the 7858 will not accept an aux input -- bummer, I had the same desire. R, Jim
Jul 01, 2008 | Alpine CDE-7858 CD Player
I pod connection
You can just use an RCA to 3.5mm (headphone) cord in one of the AUX inputs. It will sound fine, you just can't control it from the radio that way.
Mar 26, 2008 | Alpine CVA-1005 Car Video Player
Connecting ipod
Yes you can connect your i-pod to your sa-ht 930. You can buy a connection at Walmart for $5 bucks or you can go to Tareget and buy a monster connection for about $25 bucks. I bought the monster connection and works great. All you have to do is connect it to the AUX in the back to the white and red jack in put. Once you connect it change the input selector to AUX and you're ready to go.
Dec 08, 2007 | Panasonic sa-ht930 Home Theater Audio...
Kenwood KDC-MP5028
with the unit in standby, press the menu key, use the joystick control to choose aux, and set the aux option to "on"...then press menu again to save...when you next switch on the unit, using the SRC button you can cycle through the available options...cd - tuner - aux..etc etc
Oct 24, 2007 | Kenwood 2005 KDC-MP5028 CD/MP3...
Can't get componet Video to work
Make sure you have an input Video signal on that Yamaha Reciever (exa. DVD, Cable box, etc...) then choose the right input selection on ur receiver (Video1, Video2, AUX, etc..), then connect ur TV on the receiver Monitor Video out. And put your TV on the right VIDEO input too (Video1, Video2, AUX, etc..). Goodluck
Aug 10, 2007 | Yamaha HTR-5930 Receiver
Dual XDVD8181 Car Video Player Logo
22 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
