Question about Garden
My john deere 1600 weed trimmer starts fine cold, then runs on high speed for several minutes then dies .Then will not start.I cleaned spark plug, checked proper oil/fuel mix, cleaned air filter,tightened carb,all exposed screws. Thanks,Ed
  • 77 Answers
Your fuel low fuel high adj on carb arent set right. one is for idle and low running while other is for high rev. Getting these set just right is very tricky and takes some time doing it to become good,Im starting you off on a crash course,Im not gauranteeing anything but here it goes. LOcate the two fuel adj. screws on carb,if they have plastic caps on top remove them with needle nose pliers so the screws themselves are exposed. Next,I want you to take a screw driver and turn both in all the way till they stop. Now take and turn each one out counter clockwise three full revolutions. Now start it to see if theres any improvement. (Note: further adj. may be required you may have to consult an expert to have it be done for you if you cant get it).
Posted on Aug 09, 2009
John deere 420
Ignition switch could be at fault
Jul 09, 2017 | Garden
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
John Deere weed eater problems
remove the muffler and run it if it runs good after that open the muffler and clean the screen inside
Apr 01, 2012 | Garden
Weed Eater PE550...What is the proper adjustment turns for the carburetor to be set? The screw got out of adjustment. I've cleaned the filter and readjusted the spark plug gap to 0.25.
Soft seat the set screw and back out 1 1/2 turns. This is the standard to start adjustments from. Set the low speed one first, then the high. With it running and warm, couple of minutes, turn in until starts to run rough, then turn out til is starts to run rough, then set in the middle of those two points. Go to the other and repeat procedure.
Jul 25, 2011 | Garden
I have a John Deere 2E leaf blower. Lately it has been hard to start but runs fine once it is up and running. Would it help to adjust the H or L screws on the carb?
The H (High Speed) and L (low Speed) should not typically need adjustment. What happens is the diaphragms get stiff and do not operate efficiently. If the unit is over 5 years old and/or the fuel is not completely drained with the unit run dry at the end of the fall, then I would suggest replacing the diaphragms within the carburetor. This along with spark plug change, air filter cleaning and a check of the muffler to insure it is not clogged is considered a basic tune-up.
Sep 27, 2010 | John Deere Garden
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Garden Logo
119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
