Question about Samsung PCJ522R 52" Rear Projection Television
On/Off Switch not working
I have power but the on/off button isn't working. How can i fix this problem or how can i get the tv on?
  • 1 more comment
  • buccaneertop Dec 17, 2007
    when i plug the tv in, the red light comes on and stays on, put can not turn the tv on.
  • jdjackson48 Jul 17, 2008
    On/Off Switch not working or Volume not working.
    Thank you,
  • Gryndar Oct 03, 2008
    I have the same problem, only more-so, it wont turn off or do anything with the front panel or remote, even when I unplug it, when I plug it back in, it turns on but no controls work.
    HELP !!!!!!!!!!
Take a blow dryer and blow cool air on or near the power block on th inside. do so for a few secs or mins and the problem should be cured. btw unplug the tv!!!
Posted on Aug 03, 2008
    Problem Solver:
  • 10 Answers
It sounds like the tv power supply has problems. you probably should call a service center about a repair.
there are "safety" features built in to any tv with a "crt" type of screen that will not allow the tv to run when there is a problem.
Posted on Dec 27, 2007
I have a Toshiba 63hm116 TV and I think the power button on the TV just went out, how do i fix it?
Try bypassing the power button by jumpering across the two terminals. If the set doesn't turn on, it's not the power button, it's something more serious. If it does turn on, just replace the power button with any momentary switch.
Jul 20, 2014 | Toshiba Televison & Video
Techwood tv 42" model 42832 was working nipped to shops so pressed power button on side came back ten mins later switched it on and came on and changes diff colours as seen in video how can I fix this
you have a power supply partial failure if you know how to safely check your power supply check the voltages, swolen capacitors etc. leaking capicators are usually the problem. if you know nothing about power supplies do not look at the tv without the tv unplugged! better yet; have the supply repaired by a professional. a power supply can kill you!
Feb 05, 2013 | Televison & Video
Power button isn't working, but light is on inside when door opens
see the diagram attached:
You must test 1) Push button for open or dirty contact, clean and tight the wires for loose, burn, or broken. 2) Test the door switch for open or faulty switch and replace 3) After you did replace or are o.k and the problem remain the same, the motor winding or switch is defective repair.
Jun 06, 2012 | LG DLEX3070R SteamDryer Series 7.3 cu. ft....
Vizio M261VP 26'' LCD TV no picture, logo does not light up
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
May 12, 2012 | Vizio M261VP 26" LCD TV
The audio on my vizio tv isn't working
Replace the main board. That board controls all the symptoms you're having. You can get the Vizo Main Board 3642-0182-0150 thats the board for your model from it has a 6 month warranty
Feb 16, 2012 | Vizio GV42L 42 in. LCD Television
I have a Kenmore elite dishwasher about 5 years old and it will not start. The clean button keeps blinking green. Tried resetting power and still it will not start.
Makeing sure you have power is my first step.
Ensure the door isn't ajar is another possible fix...(check that door switch.)
Pressing the start / resume button again after these steps are done is all Ive got left.
I hope this helps.
Jul 17, 2011 | Kenmore Dishwashers
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
My daytec LCD TV model LM37 does not power on.
There is a manual switch on the bottom of the TV. Just flick it on and it should start to work. The switch is well hidden. It had me for a while. I was ready to go back to the store.
May 27, 2010 | Televison & Video
Is there a main power reset button. my tv just
tv's haven't used reset switches since the 70's if you have no power something inside must be blown, without knowing what model you have it could be 100 things. but i'm sure it isn;t a switch, they almost never go bad. people always think it's the power switch or the cord, because it's the only parts they know, they don't realize what goes on for your tv to turn on, it could be alot of failures. you need a repairman.
Sep 15, 2009 | Televison & Video
My kid power off tv by power button on tv, next time i could not
switch tv on the switch can not contribute to that. unless the following goes fault
i switch getting fixed on one position(holding)
ii check power on a input of tv and input fuse
iii power supply, i have said that because if a power supply is ok, sound was going to be there.
Nov 22, 2008 | Samsung TXG2547 25" TV
Samsung PCJ522R 52" Rear Projection Television Logo
74 people viewed this question
Jerry Greenberg
Jerry Greenberg
