Question about Jacuzzi WATER RAINBOW FILL SPOUT 6000-917
Water Leak from Jacuzzi Water Rainbow Fill Spout
I purchased my used home recently, and I have a water leak from the spout when the water is turned off. I do not have an owners manual. How do I go about repairing the leak?
  • 3 more comments
  • Colin60 Aug 04, 2009
  • Colin60 Aug 10, 2009
    Thanks. I'll give this a try.
    Hi:
    I have looked at the Spout assembly and the valves located in the cold and hot water handles. They do not appear to have the characteristics of Deeathstalker's description. The handles simply lift off, with no screws, and what I see underneath is different.
    Hi:
  • Kenneth Reaume' May 11, 2010
    Can you look around the spout or the handles and tell me the brand name on it please I can then walk you through a step by step repair. Thx
  • 123 Answers
Ok you will need to replace the rubber seat and spring under each valve. You start by removing the plastic insert in the center of the valve. Remove the screw inside of handle and pull handle off. There will be a gasket under that and then you will see a bonnet. MAKE SURE THE MAIN WATER IS OFF before you proceed any further. Remove the bonnet by turning it counterclockwise. Once you have removed the bonnet then pull the stem out make sure you take care to notice exactly how it came out. Underneath the stem is a rubber seat and spring you can use a phillips screwdriver to insert in them and remove both. Replace them with new ones and re-install. If you are not very good at this sort of thing I recommend you call a repairman. Inserting of the stem back in its proper place is extremely important as it has to seat or it will not function properly. If you have any questions just ask.
Thx
Posted on Aug 04, 2009
  • Kenneth Reaume' Aug 22, 2009
    Hey there ...........I see that the description I gave you was not the same as what you have. That description came directly from the manufacturer. Please try and describe to me exactly what you see when you remove the handles so I can determine the proper steps in removing the stem to replce the seats.
    Thx
    Deathstalker
    P.S. we have a premium chat service if you wish to use it as I could chat with you directly and walk you through the steps.
How to flush out the water heater
Connect one end of garden hose to spout located near bottom of water heater. Put other end near drain or run to outside whichever suits your particular situation better. Shut off water valve at top of heater and open spout to drain. You might not have to drain the whole thing if you do this regularly. If it's never been done before you probably should. When water stops draining out shut off spout and open valve at top of tank to fill it back up. Disconnect garden hose. Water will be cold for about an hour before it has a chance to heat back up. Should be done about once a year or so depending on your water unless you have a self cleaning water heater.
Feb 09, 2013 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
How do I fill water heater
Once the hot and cold pipes are connected to water heater, then open bathtub spout on hot side, turn water on so tank begins to fill.
After tub spout is running full stream without air, then water heater is full and it is safe to turn on the heater.
Turning on gas water heater before tank is full can damage tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Turning on electric heater before tank is full will burn out elements. Replace elements.
http://waterheatertimer.org/How-it-works.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water is leaking from a whole in the top of the water heater what is the cause
If water heater is leaking out of a hole, then tank is rusted out and needs to be replaced.
http://waterheatertimer.org/Leaking-water-heater.html
First thing is protect yourself.
Tank could rupture.
Turn off power
-Electric heater: turn off circuit breaker
-Gas heater: turn knob from ON to pilot, so pilot light stays lit.
Open bathtub spout on hot side and release pressure.
Now you're save.
When you need hot water, turn heater on for 1 hour, use hot water, then turn heater off again.
You can limp along like this for a while until heater is replaced.
I buy water heaters at Lowes, Ace, Home Depot, Sears.
Look for scratch and dent.
Look for same size that you have now.
manufactured homes require heater that is made for that application.
Propane and natural gas heaters have different burner.
Always offer 10% less than asking price on any water heater.
You need teflon tape, 10" pipe wrench, new flexible water connectors, and a drip pan, and maybe insulation blanket.
Read how to install gas water heater.
To install electric water heater, open link above because some things are same for both gas and electric.
Difference with electric is there is no gas line, and you connect wires same way that they came off.
Feb 04, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water comes out spout and shower head at same time
Hello gruber d, you need a new spout. When a spout is working properly you raise the knob on top and it slides a baffle over the outlet at the spout. Once the water is blocked from flowing out of the spout it forces water up and out of the shower head.
You may also remove the spout and see if you can get a closer look and see if you can make some kind of adjustment to it.
Removing the spout;
1. Put a cloth around the spout to protect the finish.
2. Adjust a pipe wrench to fit over the spout and the cloth.
3. Turn the spout counter-clockwise to loosen.
My goal was to provide timely and accurate information. If this has been helpful to you, please
consider taking a second to click on the, " this was helpful ", button.
Than you!
Jan 13, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
My reliance sta-kleen 502 is leaking. The water is dripping on top of the pilot light, extinguishing the flame . Please advise me with step by step instructions to diagnose and attempt fix this myself....
If you have a leaking water heater there is a serious problem.
http://waterheatertimer.org/Water-heater-leaking.html
Page shows how to limp along on a leaking water heater if your water heater needs replacement.
One of three things is causing the water:
1) Loose water connection on top of tank that is dripping down inside tank >> check pipes on top of tank.
2) The vent is clogged or not working correctly causing condensation inside flue pipe.
Condensation water is dripping back down inside tank.
Problem means possible CO poisoning if gas is not venting.
Look at vent pipe to see if joints are corroded.
Use long fireplace match > light match and put into draft hood at top of tank and see if smoke goes up.
Put hand at draft hood opening when water heater turns on to see if vent gas enters home.
Do same test when furnace turns on to see if furnace vent is pushing back into water heater.
Does water heater vent inside same pipe as furnace? You may need to set up separate vent for water heater if furnace gasses are pushing back into home.
Check furnace vent for obstructions.
Look at vent stack top of home to see if hood is in place.
Check if bird nest is built inside warm vent pipe.
Improper flue is top priority for getting fixed so vent gasses properly escape home.
You may have to call a plumber.
Professional plumbing forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Your water heater is rusted out.
A rusted tank has to be replaced.
It cannot be repaired.
However, before replacing tank, you do not want a tank failure where tank ruptures and water runs inside home until water is shut off.
This will cause major damage.
Protect yourself first.
Turn off water valve above tank.
Move gas knob to 'pilot' so burner is not heating water.
Open tub spout on hot side to relieve pressure on tank so it will not rupture.
Now you're protected.
Link above shows how to limp along on failed tank until you can replace heater.
You need a new gas water heater from Lowes or Home Depot
Look at label on side of you tank for gallons and btu's of your water heater.
Measure height to flue pipe so you get same height water heater, so pipes don't have to be changed.
You need a pipe wrench and teflon tape which will be wrapped on each pipe thread when pipes are reassembled.
Step1) Drain water heater using valve at bottom of tank.
http://waterheatertimer.org/Water-heater-will-not-drain.html
2) Turn off gas valve going into heater.
When gas valve is perpendicular to gas line, then gas is off.
Dissemble gas line to water heater.
3) Disconnect flue pipe and support flue pipe with wire so it doesn't not fall down. Flue pipe joints should be held together at each joint with 3 screws.
4) Turn off water. Shut off valve is on COLD side.
Disconnect water pipes.
5) Move old water heater out of way.
6) Set new water heater in place. Put water heater in drip pan.
7) Connect water pipes >> cold goes to side marked cold.
Hot to hot.
Buy new flexible water connector pipes at home center for easy installation of water pipes.
8) Connect gas line exactly as it was connected before.
Home center sells flexible gas line connector for easy installation of gas line.
To test for gas leak after installation, mix liquid soap with water and put around gas line joints to see if there are bubbles.
Natural gas has less pressure than water lines, so gas pipes are easy to seal with ordinary wrench.
9) install TP pipe that runs to floor. Use old one off old heater.
10) Fill tank completely with water until water is coming out of tub spout.
11) Turn on gas, and light pilot as shown in manual.
New gas heater sometimes have small water leak when first fired up, so ignore a bit of water.
12) Save water heater manual like it is gold, and read everything in manual.
Dec 18, 2010 | Water Heaters
Slight water leak from plastic drain fitting on rheem fury 40 gal gas water heater
You can try to crack it open and get a little piece of crud out of there, I'm sure that is all it is, Just get a tray or something to catch the water, It should stop it, If it gets worse, turn the water off to the heater, then open the valve and hope the bigger piece of crud comes out. It is about all you can do, other than drain the whole thing and take the valve apart and replace the rubber in it. Check it out, Hope this helps.
Dec 12, 2010 | Rheem Water Heaters
Leaking water heater, the spout on the side is dripping water all over the basement floor.
You can try fixing this problem by putting a garden hose cap over end of valve.
Cap has a washer.
If leak is bad, you need to replace drain valve.
If the valve is brass, then drain water heater and put a wrench on valve and unscrew.
Buy replacement brass valve from plumbing supply or Lowes-HomeDepot
If the valve is plastic, then expect it to break off when trying to remove.
If it breaks off, then you can carefully drill out the stem, and then burn it out with a torch and use a 3/4" pipe nipple to try to cut a new thread.
If water heater will not drain ... put washing machine hose on water heater valve - run water hose between washing machine hose and outdoor spigot and turn on water for 10 seconds to break open clog inside water heater.
Oct 25, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Bottom tank leak
is there a spout there if so then u hav to find away to remove the rest of the pipe in heater to expose the threads and go to ur local hardware store to get a replacement spout looks like something u would hook up a water hose to hope i could help
Apr 21, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Nozzle leak
If it leaks out of the spout replace valve. If it leaks out of knob post replace packing seal. You might get away with just tightening packing cap.(The 1st nut under handle). Try small increments or you might split packing .
Apr 16, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Leaking braided water line from under spout LITTLE GOURMET
you will have to get a replacement from the manifacture,, they will send it to you, call them tell them wich one it is hot or cold they may have diffrent threads then again they may be the same,,,can you get the threaded part out of the faucet, you will need an extractor, you can get this at a hardware store, it has a rubber seal so you can only tighten it so much, get it ot try again but be gentle,, one thing I found after doing plumbing for 34 years if you snug it and it leaks you can always snug it some more if you over tighten it you can't do anything but replace it,,,, good luck let me know how it goes
Jun 21, 2009 | Mountain Plumbing Mountain The "Little...
Jacuzzi WATER RAINBOW FILL SPOUT 6000-917 Logo
978 people viewed this question
Top Jacuzzi Water Heaters Experts
Nicola Conroy
ray gallant
Are you a Jacuzzi Water Heater Expert? Answer questions, earn points and help others
