Question about JBL GTO 301.1 Car Audio Amplifier
Amp switches from power to protect over n over
My amp keeps switching from protect to power. wtf is goin on?!?!?
  • 655 Answers
Hello ryan_waslike,
There's a short or a ground somewhere on the system.
Start by checking your wiring and make sure there are no shorts and that there isn't any insulation rubbed off allowing a wire to come in contact with the vehicle metallic body or frame. Then disconnect the speaker and see if the amp will power up without going into protect. If it does, the problem is in the speaker or speaker wiring. Find and correct the problem and power everything back up.
Hope this helps.
Posted on Aug 03, 2009
Pyle 2210 how to test the amp when it keeps goin
when the amp goes into protect mode, it is more often than not a problem with the speakers or the speaker wiring.
Sep 01, 2014 | Car Audio & Video
My Yamaha SW118 keeps cutting out (volume reduces to v low level) even when driven by 500W amp. Doesn't seem to be the amp but not sure if the speaker has it's own internal protection. Can anyone advise?
Poly Switch
All full-range loudspeakers are fitted with a self-resetting
poly switch that protects the high-frequency driver from
damage caused by excessive power.
If a loudspeaker cabinet loses high-frequency output, immediately
remove power from the unit and wait for two to three
minutes. They should allow the poly switch to reset. Reapply
power and check the performance of the high-frequency
driver before continuing with the power reduced to a
level that does not cause the poly switch to interrupt the signal.
On the SW115V/SW118V/SW218V sub woofer, the Poly
Switch protects the woofer and a similar routine should be
followed if its output is lost.
Aug 29, 2010 | Yamaha SW118-IV 18" Subwoofer Speaker
My 1997 Ford F250 power stroke deisel 7.3 keeps blowing fuse #17 10 amp when I put it into Drive
Fuse 17 10amp protects the following 1)transmission control switch and lamp. 2)brake fluid level switch 3)warning chime 4)diesel warning lamps display 5)fuel water switch 6) low vacuum warning switch 7)instrument cluster 8) switch lamps,,,,,,,,,,,,,, i think your problem on transmission control switch, check also brake light and brake switch
Jun 21, 2010 | 1997 Ford F250 SuperCab
Protect light keeps comin on
MAKE SURE THE GROUND IS GOOD ON BODY OF CAR BOTH UNDER THE HOOD AND WHERE YOUR AMP IS GROUNDED
Apr 18, 2010 | Infinity Reference 1300a Car Audio...
My amp keeps goin into protection
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your amp is probably OK. The volume is either set to high or the speaker load is to low of an impedance. Remember 2, 8 ohm speakers connected is the same as 1, 4 ohm speaker. Another possibility is that you do not have enough battery power coming to the amp itself. A simple rule I use is take the watts and divide by ten, that will give you an approximation of the amps needed on a 12 volt system. This takes into account some of the losses in the amp, but it is only an approximation. For example 300 watts RMS is 30 amps, which will require a number 8 wire to keep the losses at a minimum. You can check wire drops on the web.
Good Luck,
Gilshultz
Nov 29, 2009 | Kicker ZX1500.1 Car Audio Amplifier
Hi. I have a Kicker amp KX1200.1 that doesn't seem to be working. I think it blew a fuse. Do you know how I can get that fixed?
You should have an inline fuse (external) at the amp and one at the battery. There are not fuses on the amp.
Jun 25, 2009 | Kicker KX1200.1 Car Audio Amplifier
No , i cnanot switch the phone in my pocket pc
WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?
SPEAK ENGLISH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Apr 01, 2009 | i-mate JAQ3 Smartphone
Keeps swirching to protect mode
First thing to do is disconnect all of the speaker wires on the amp. Turn on the amp, if it is still turning on and off then there is a definant problem in the amp circuitry. If you have no solid state service skills, I highly advise you to take the amp into a repair shop. If it stops turning on and off turn off the amp and try and connect up one speaker at a time untill the amp starts to mess up. you then take that speaker and have it checked out and inspect the wireing for pinchs or shorts.
Oct 03, 2006 | JBL GTO 301.1 Car Audio Amplifier
JBL GTO 301.1 Car Audio Amplifier Logo
181 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
