SOURCE: Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
SOURCE: open heat error on gestetner
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
SOURCE: Gestetner 5308bt copy printer error after switching
This is a cutter error. Check the following.
Master cut error occurred
Cutter switch
Cutter motor
Cutter drive mechanism
Open the side the master is loaded. Check that the cutter is in the home possition and that there is no used master stuck in the machine. Check the motor by entering sp mode
Function clear "107" press and hold C/clear
"131" #
"23" Start key
will return cutter to home position.
Press funtion clear to exit.
If the motor is not running you will have to replace it.
SOURCE: on an HP 2430 printer I get a 59.60 printer error.
Here is a web page with the HP errors. Looks like it might need servicing.
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=pl&cc=pl&taskId=110&prodSeriesId=1839844&prodTypeId=18972&prodSeriesId=1839844&objectID=c00784943
