Question about Frigidaire FGB24S5A Gas Single Oven
Oven only works sometimes - Frigidaire FGB24S5A Gas Single Oven
  • Frigidaire Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on May 18, 2010
My Maytag oven works when it wants to when I heat it up it take forever and then sometimes it will stay heated at the temperature I set it at and sometimes it just quits and wont start heating again after...
The number one problem for these ovens is the ignitor. This one is your ignitor according to your model number When it is weak it is intermittent. Sometimes you can get the oven to work if you give it a swift kick. This video explains how it works:
The next likely suspect is your oven sensor. That is the link to your oven sensror according to the model number you posted. Here is a video which shows how to check it:
Jun 14, 2011 | Maytag Ovens
Intermittent ignition problem. Sometimes clicks, sometimes doesn't.
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 07, 2010 | Ovens
Frigidaire Oven
DO NOT USE THE OVEN until you replace oven control
thank you...garing
l
Aug 06, 2009 | Frigidaire FGB24S5A Gas Single Oven
The display on the oven has completely stopped
try to repair it, but ask for the price first, if it's too high, just buy a new one
Jul 21, 2009 | Ovens
Kenmore gas range model# 362.72321 Oven will not ignite (sometimes)
Range Oven Temperature Sensor Part Number WB20K0004 Sears PartsDirect
This will be why the oven acts up. The broiler doesn't rely as much on this as the bake part does. Replace this and it should fix your problem.
Jun 14, 2017 | Ovens
Instructions required
I have a GE double oven. JKP44G with touch pad controls
Top oven door will not lock for cleaning cycle. I think I need a new motor for that.
Bottom oven will work sometimes and other times when I turn it on and select the temperature, thinking it is coming on - all of a sudden the temp light goes out like the oven is off and the oven does not heat. Sometimes I touch the clear button and then turn it on. Sometimes it works and other times not.
Could the connections in the control panel be dirty and not making connection at times?
Main question. How do I get to the control panel. How can I pull the oven out to clean the circuit or connectors and change the door motor. If I could just get into the panel I feel I could fix it.
Nov 14, 2008 | Ovens
Kenmore oven model # 79071053400
Check for a loose bulb or faulty door switch. Sometimes a bulb can fail and the filament can reconnect to work at a higher wattage before failing completely.
Jun 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ge Electric Double oVen
This may be related to a problem I have helped others solve. The solution is available free at my website. I have at last count helped over 1000 oven owners with a similar problem. http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Hope it works for you too.
Aug 09, 2007 | GE JKP45 Electric Double Oven
Frigidaire FGB24S5A Gas Single Oven Logo
69 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
