Question about Video Cameras
I got a Sony HandyCam FFCCD-FX330 camera from a friend, with its battery, AC adapter, and cables. It powers on and appears to record to the tape, however nothing shows on the viewpiece. All I can see in the view piece is a white screen. Occasionally it flickers, as if something was getting through, but most of the time it stays white. It does not show what's being "seen" by the lens, and does not show anything in playback mode. Does anybody else have this type of camera? Do you know what's wrong with it?
  • 1 more comment
  • freelandrent Aug 02, 2009
    In response to tommya300: The lens cap is off the lens. I double checked it first thing off when I noticed the problem. Do you think it is just dead, or is there an easier solution?
    The tape is feeding, I see the wheels turning inside the holding area. There doesn't appear to be an edit switch. There are play, pause, stop, rewind, and fast-forward buttons, but those are only for playback. Switching to playback doesn't help either, the screen still stays white.
    The backlight button doesn't help, and all the switches seem to be in the right positions. There's one for the camera setting (off, camera, or playback) and one for the record setting (lock or standby). I made sure to turn each of them on and still just a white screen on the view point.
  • freelandrent Aug 03, 2009
    I took a look inside at the circuit to the CCD. The cables appear to be intact. I removed and replaced them just to make sure. It didn't fix my problem.
    So you're thinking a bad circuit?
  • 724 Answers
Lens cover or cap is not open ?
Posted on Aug 02, 2009
  • 1 more comment
  • tommya300
    tommya300 Aug 02, 2009
    can you see the tape is feeding? Is there an edit seitch on the side and an in out switch see itf they do anything a backlight button a lock button investagate these options see if there is a combination of switch settings
  • tommya300
    tommya300 Aug 03, 2009
    Was ther camera ever taken appart? There are only 2 more things I can think of where the ribbon cable for the ccd is not in place correctly. the other bad CCD or circuit.
    Even if you have trouble taping you should see an image just in the standby mode...
    Sounds like the power cable to the ccd is dislodged
  • tommya300
    tommya300 Aug 04, 2009
    At wost case the CCD circuitry.
    Is there a fade button under the front nose or somewhere on the camera maybe that can be stuck. I can not think if anything try a different tape...
    Did you try playing the tape after videoing use it in a different play back machine
    Maybe the viewer wires got messed up from moving or adjusting it for viewing something chaffing the insolation where it is bent comming out of the viewer inside
Sony dcr-pc9 ejects tape when trying to load....not a claening issue..common symptom on this model
Try this:
1. Turn off the Handycam
2. Remove the battery from the Handycam.
3. Remove the AC Power Adapter from the Handycam.
4. Move the Handycam power switch to the ON position.
Note: Leave the switch in the ON position for at least 15 seconds.
5. Move the Handycam power switch to the OFF position.
6. Connect the AC Power Adapter to the Handycam.
7. Turn on the Handycam.
Apr 05, 2011 | Sony Handycam DCR-PC9 Mini Digital...
Video Camcorder Error Message
Per SONY; To service the C:31 code, Sony recommends you do the following: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required.
Sep 15, 2007 | Sony Handycam CCD-TRV608 Camcorder
Sony 700X digital handycam
solution 1: Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. solution 2: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required. If your camcorder still shows the same error code, then you'll have to send in your camcorder for service additional info that might help: According to the manual, the error code C:31:xx:xx means an error that >the owner can fix by himself has occured and that by taking out the >cassette and replacing it or by disconnecting the battery pack and >fixing it back should solve the problem. Error "23" means: "S reel emergency during normal rotation", i.e. the problem is with the tape deck mechanism and specifically the supply reel.
Aug 21, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony DCR-TRV17 - In the middle of filming, a flashing yellow square with a yellow light bulb inside the square appears wiht chimes. upper right hand corner is flashing C:21:00. I turned off recorder and...
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
May 31, 2010 | Sony Handycam DCR-TRV17 Mini DV Digital...
My Sony Handycam DCR-HC26 started giving me C:31:23 error ''Reinsert the cassette'' when I try to record on a new Sony tape. I am however able play back a previously recorded Sony tape.
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
Mar 18, 2010 | Sony Video Cameras
I get a error code 30:23 on my HDR HC3 and it won't play or
Sony is pretty secretive about the :23 code. It can't be found anywhere. Sony recommends you do the following:
  2. Remove the battery or disconnect the AC power adapter for 120 seconds.
Nov 12, 2009 | Sony Handycam HDR-HC3 HDV Digital...
My Sony TRV118 displays C:31:23 when trying to playback or record. Have tried different tapes, left open for sometime, removed battery. All to no avail.
The camcorder has detected an issue that may require a power reset.
Aug 12, 2009 | Sony Handycam DCR-TRV118 Camcorder
When tape inserted re insert tape and C 31:23 APPEARS
The camcorder has detected an issue that may require a power reset. To perform Power reset,
Aug 04, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
When tape inserted "C:31.23" flashes
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Mar 24, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
Video Cameras Logo
216 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
