Question about Yamaha DVD-C940 Multi-disc DVD Player
My yamaha is flashing and saying clamp block on screen
Starting problems
Yamaha's are a bit cold blooded. Determine if it's compression, ignition or fuel. If your compression is good, next try a shot of starting fluid into the air cleaner, only use a bit and shoot some in while turning the starter or have someone shoot some in and kick it over immediately. If it starts or at least shows some life, your problem is in the fuel supply or carb. 60% of troubles I see is due to modern day crappy gas. Never use fuel with alcohol (oxygenated) and do not use gas more than 90 days old unless it was treated with a stabilizer.
Next step is check your spark. I prefer using an old spark plug gapped wide, say .040, and clamp it with a hose clamp to a battery charger alligator clamp to ground to the engine. You should see a consistent blue spark. If you have electric start, spin the motor for say 30 seconds and feel the heavy positive that goes to the starter, or the heavy ground. If it feels warm and/or if your starter doesn't smoothly turn over, a bad starter can take power away from the ignition.
Apr 16, 2014 | 2006 Yamaha Ybr 125
2005 yamaha R1 Code 17 Exup servo
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Error Code 17
http://www.cycleforums.com/forums/53-yamaha/294046-2007-r1-error-code-17-exup-valve.html
2004 2005 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jun 06, 2012 | 2005 Yamaha YZF-R1
Torque specs for yamaha R1 triple clamp bolts
Hi, Tom for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/4-mechanical-help/315309-torque-specs-09-r1-triple-clamps.html
http://www.r6-forum.com/forums/57-garage-mechanical-help/138904-torque-specs-2006-r6-triple-clamp-allen-bolts.html
Jan 20, 2011 | 2004 Yamaha YZF-R1
How do I remove the gas tank on a 2008 roadstar with fuel injections? Igot all the way to the 2 last ubes ...one with a standard clamp and the other with a blue plastic clamp but now i am baffled. Any...
Hi, Caronmpc for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Roadstar Tank Removal Yamaha Road Star
Roadliner Gas Tank Removal
Yamaha XV1700P Service Manual
Yamaha RoadStan XV17AWW Owner Manual
Mar 14, 2010 | Yamaha Road Star Silverado Motorcycles
My xbox 360 starts up ok its only when i try to play a game the screen goes black or it freezes with white blocks on the screen
it sounds like an error with you gpu chip you need to google x clamp repairs and buy a x clamp repair kit from ebay this should solve the graphics error
Oct 31, 2009 | Microsoft Xbox 360 Console
My calipers wouldnt compress so i took them off now they wont go back on..help
BRAKES are one of the things you dont play with as your life and other peoples depend on them being done correctly, but concidering that you have got them off and carnt get them back on-------- take off the top of brake tank then take out the pads (1 side at a time)now compress the piston with a G clamp back as far as it goes ,then refit pads and refit
caliper and tighten up tight and then pump pedal 3 times and now turn the disc it should be a bit tight to start with.
THE other side take out 1 pad and retract the piston back to the stop ,put in new pad and then the other one .do the same pump the pedal and recheck the rotor for turning refit brake tank lid.
Road test burn them in a bit before rechecking disc for free spinning
Oct 13, 2009 | 2005 Mazda 3
I know my 2005 r6 has inverted forks and was curious if a 2004 clamp would fit? btw can someone explain to me what inverted forks mean? and why is this only on the 2005 r6? thanks
I'm not sure about the clamp, but the inverted forks, I know about.
If you look at how the forks are set up on your 2005, and look at, say a 2004,the forks are your look upside down. The metal part of the tubes are on opposite ends from 2004 to 2005, and I'm thinking it's only the 2005 because Yamaha most likely just wanted to try something different in styling for the year.
Aug 11, 2009 | 2005 Yamaha YZF-R6
Distortion with colors
its the graphics card i had the same problem soon your gonna get e74 and your gonna have a large white paper weight
Jun 29, 2009 | Microsoft Xbox 360 Console
Won't stay powered on
There is a relay right next to the fuses on the inside dg1u it says on the top. I cleaned it and pressed down firmly on it and it seem to have fixed it. It fired up for the first time.. The relay might need to be replaced if this doesnt work for ya.
I found a solution at: http://www.diyforums.net/forums/domestic-electronics/11098-yamaha-rxv795-receiver-shuts-itself-down-after-some-time.html
Dec 23, 2007 | Yamaha RX-V795 Receiver
Yamaha DVD-C940 Multi-disc DVD Player Logo
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
